Re: Using the cRIO to control custom lights
Some Electronic Speed Controllers are significantly less expensive than a Jaguar. (I've seen a circuit you can build with less than $15 in parts, though one of them is a PIC that needs to be programmed.)
Stepping out of the box for a moment, would a mechanical solution work? You could use a servo to open and close a shutter on an always-on lamp. |
| cRio keeps on staying red on the lab view conection test all other 4 lights are green | bio hazard | NI LabVIEW | 2 | 11-03-2010 16:48 |
| Using Sockets with the cRio in Wind River | C222 | C/C++ | 15 | 17-02-2009 14:10 |
| purchasing buying the 2009 NI cRIO control system | martin417 | FRC Control System | 10 | 29-12-2008 12:31 |
| Lights on the Control Panel | Han Tzu | Electrical | 5 | 08-02-2005 13:30 |
| Using Custom Inputs on the Controller Board | schenkin | Programming | 10 | 27-01-2005 10:26 |
