Go to Post C'mon you guys you're all inventors. You guys should be making a portable cryogenic sleep chambers for those long bus trips! You got two weeks before you have to go. Get cracking! - Koko Ed [more]
Unread 07-04-2009, 23:50
Covey41 Covey41 is offline
Covey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of lightCovey41 is a glorious beacon of light
Interesting speed test
All the Ham Radio Operators on Chief Delphi will find this interesting.
http://www.youtube.com/watch?v=hc5j4Bia9nI
If you're going to Atlanta check out www.w4doc.org
73
WA1MOW
"One day you will come to a fork in the road. And you're going to have to make a decision about what direction you want to go." Boyd raised his hand and pointed. "If you go that way you can be somebody. You will have to make compromises and you will have to turn your back on your friends. But you will be a member of the club and you will get promoted and you will get good assignments." Then Boyd raised the other hand and pointed another direction. "Or you can go that way and you can do something for your country, your Air Force and for yourself. If you decide to do something, you may not get promoted and you may not get the good assignments and you certainly will not be a favorite of your superiors. But you won't have to compromise yourself. You will be true to your friends and to yourself. And your work might make a difference. To be somebody or to do something. In life there is often a roll call. That's when you will have to make a decision. To be or to do? Which way will you go?"
Unread 08-04-2009, 02:11
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: Interesting speed test
That was an interesting idea. I'm really not that surprised though. The question is, what do you attribute it to? I personally think it is user interface. He didn't have to search for the keys. He had one button. He just had to push it wisely.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 08-04-2009, 07:45
Without really knowing for sure, I would guess that the Ham was sending at something like 20 words per minute by the sound of the code. It took about 18 seconds to send the message via Morse Code. It looked like they were using one of my favorite rigs, a Yaesu FT-817 as well. Code operators, by the way, have been using short hand (abreviations) in sending messages for a long time. One of the nicest things about using code in ham radio is that it can still transmit a message even when signal conditions are so bad that the noise is louder than the signal. This is impossible for analog voice communications.
Unread 08-04-2009, 08:41
ScottOliveira ScottOliveira is offline
FRC #3455 (Carpe Robotum)
ScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really niceScottOliveira is just really nice
Of course, the two Morse code guys were very experienced. 38 and 43 years, competing against a pair of guys in their teens/twenties. Something to be said for practice.
Unread 08-04-2009, 10:53
Scott,
Even out of practice I can do between 5 and 10 WPM. Give me a few minutes and I can get back up higher. Prior to April 2007 (I think) all ham license classes except Technician, required a code test. Novice was 5 WPM, General and above was 13 WPM both for send and receive. Many years ago, the upper classes also required higher code proficiency. Extra as I remember may have 20 WPM. Radio operators in WWII were required to copy 5 letter nonsense groups at 35WPM or above, some while typing. The traffic was coded so nonsense was intentional.
Unread 09-04-2009, 10:09
Team2339's Avatar
Team2339 Team2339 is offline
Mentor#1
AKA: Myrle McLernon
FRC #2339 (Robolopes)
Team2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to beholdTeam2339 is a splendid one to behold
They weren't sending that fast, just smart. Good fist.
I wonder if there is an I-phone morse code app?
KQ6Y
2008 LA Regional
2009 San Diego Regional 5th Seed, 2009 Las Vegas Regional Semi-Finalist
2010 San Diego and LA
2011 Bound for same
KQ6Y
Scientia Super Omnia
Unread 09-04-2009, 11:39
KQ6Y
Is that a new oxymoron?
Unread 09-04-2009, 11:51
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Here are some background details on the video clip:
http://www.arrl.org/news/stories/2005/05/16/3/?nc=1
What really drives me nuts is I have friends who can sit there and work CW at 30+ wpm in a contest, while talking to whoever is sitting next to them. I struggle at 5 wpm
73 de K0JSP
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 09-04-2009, 12:47
boomergeek's Avatar
boomergeek boomergeek is offline
AKA: Mr. D (Dick DiPasquale)
FRC #0241 (Pinkerton Robotics)
boomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant futureboomergeek has a brilliant future
The cellphone users do not seem to have been FIRST material.
I would have clicked a picture of the message card and had the pic message on the other cellphone in less than 5 seconds (trouncing the speed of the Morse Code guys).
Or even better, I could have had a pair of eight year olds do it.
Unread 09-04-2009, 13:59
Jeff,
Remember contesting uses a limited vocab.
Unread 09-04-2009, 14:10
Which is outside the box, like a 150 lb robot without the batteries or bumpers, I'm sure. Does it do the job? Yeah. Is it legal? Nah. Why? It's sending TEXT, not pictures.
If you're going to use a pic message, then I'll just use voice and have it there faster. I can read that message into the phone in less than 5 seconds, and it'll be understandable. And yes, that is still using "old" technology.
Unread 09-04-2009, 14:19
If you're going to use the voice on the phone, I'll just run over and give him the message. (I could just shout it out, but then the other guy would hear it too!)
Unread 09-04-2009, 14:31
Jeff Pahl's Avatar
Jeff,
I know, but it's still annoying to those of us who struggle to be able to do it at all
People with musical inclination take to CW much better than those of us who struggle to play "Mary Had A Little Lamb". The military actually came on campus and recruited some of my wife's college classmates who were music or music therapy majors as high speed CW intercept operators. They were taught to be able to receive nonsense character groups at 50+ WPM (since anything they would be copying off the air would be encoded). That was "a few" years ago, I don't know if they still do that.
Unread 09-04-2009, 15:05
Aren_Hill's Avatar
Build Nifty Things
Must say i'd prefer texting, because I'm completely familiar with my qwerty keyboard and can use that familiarity for other things, morse code on the other hand would still be nifty
KDOHFT (very recently became licensed for the solar car team)
A guy who likes robots.
Unread 09-04-2009, 15:18
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
wow,
seems like alot of people have their liscence........
my dad and his dad used to do this. we still have all the equipment...
I should probobly go get my liscence.......
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Interesting IR sensor test results Mr. Freeman Technical Discussion 18 08-01-2008 16:14
Interesting speed reducer mechanism Dick Linn Technical Discussion 15 08-09-2007 18:09
What speed do you surf the net? Take the test! Elgin Clock IT / Communications 77 30-03-2005 16:28
Speed Test! MattK Website Design/Showcase 20 21-03-2004 20:45
