Go to Post OMFG! Sanity prevails! It's unprecedented! - Kevin Sevcik [more]
Unread 09-04-2009, 13:02
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Using the cRIO to control custom lights
Note that if you want to use PWM to control transistors or LEDs directly, you will have to write your own pulse code and use a digital output (whether signal outputs on the 9403 or driven outputs on the 9472). The PWM being output from the ports labelled PWM on the sidecar is an R/C standard servo control signal, which means the PWM duty cycle ("on time") will vary between about 7.5% and 12.5%, which means you'll barely be able to see an transister-controlled incandescent, and an LED probably won't turn on even at maximum output.
--Ryan
FRC 766, 2015-, Mentor
cRio keeps on staying red on the lab view conection test all other 4 lights are green bio hazard NI LabVIEW 2 11-03-2010 16:48
Using Sockets with the cRio in Wind River C222 C/C++ 15 17-02-2009 14:10
purchasing buying the 2009 NI cRIO control system martin417 FRC Control System 10 29-12-2008 12:31
Lights on the Control Panel Han Tzu Electrical 5 08-02-2005 13:30
Using Custom Inputs on the Controller Board schenkin Programming 10 27-01-2005 10:26
