Go to Post My nephew...loves FIRST. He wants to be an X-Cat but since he lives in Atlanta and that's a heck of a long commute for meetings I told him he probably should strive to be the next best thing: a CircuitRunner. - Koko Ed [more]
Unread 04-10-2009, 07:47 AM
Jared Russell's Avatar
Taking a year (mostly) off
Re: voltage-torque curve
Originally Posted by kamocat View Post
Are you saying that a CIM at full-forward with the battery at 11.5v will perform differently depending on whether the battery is drawn down under load or simply drawn down over time?
11.5V is 11.5V, regardless of how it got to 11.5V.
A CIM will perform differently connected to an 8V, 10V, or 11.5V source than it will to a 12V source. And because our batteries are not ideal voltage sources (they have a built-in resistance) and our wiring is resistive, their terminal voltage will drop under load. So pull a lot of current from your battery (say, by stalling your drive motors) and you will find that your shooter, for example, has slowed down because the effective instantaneous terminal voltage of your battery has dropped.
Effects like this that prompt Al to correctly say that claims of motor response "linearity" are dependent upon many factors besides the speed controller response.
torque curve LIL_C Technical Discussion 0 01-12-2008 02:02 PM
Acceleration Curve EricWilliams Programming 5 02-01-2006 04:27 PM
van door torque curve DLyons Motors 1 01-13-2003 09:54 PM
Drill motor torque curve thedillybar Motors 1 03-10-2002 05:19 AM
Voltage Byte -> True Voltage Ulibrium Technical Discussion 11 03-01-2002 08:55 AM
