Go to Post You can never have enough figurative language. - Travis Hoffman [more]
Unread 10-04-2009, 14:34
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
0.502" Drill bit?
In attempting to make a couple of hubs this year, we bored out some aluminum stock, like ya do, on our lathe. We used a 1/2" bit since the motor shafts are a 1/2" diameter. However, the holes were too press fit for our liking -- we wound up having to sand down the motor shaft a bit in order to get the hubs on the motors.
In the future, I'd like to alleviate this. I've noticed that AM's sprockets and some gears come with a 0.502" hole -- which is great because it takes no effort to put on and remove their hubs (well...most of them ). However, in my searching I've come up blank thus far in looking for a drill bit larger than a 1/2". Any suggestions? I'd like to find a better solution than grinding down a shaft.
GitHub
Unread 10-04-2009, 14:39
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
Re: 0.502" Drill bit?
Use a reamer, like this one: http://www1.mscdirect.com/CGI/NNSRIT...MT4NO=61815556
The process is to drill (or bore) the hole slightly undersize, by a few thousandths, then to use the reamer to open up the hole to the precise diameter.
I'm sure others will jump in here with more precise instructions.
And MSC also sells drill bits larger than 1/2". They used to have a discount for FRC teams, but I don't know if that is still the case.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
Unread 10-04-2009, 14:40
DB_UPS's Avatar
DB_UPS DB_UPS is offline
tool or die that is the question?
AKA: Ryan Quinlan
FRC #1675 (The Ultimate Prtoection Squad)
DB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura aboutDB_UPS has a spectacular aura about
Send a message via AIM to DB_UPS
*beat to it*
Unread 10-04-2009, 14:41
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you don't need a precise fit, you can waller out the hole with the drill
If you do need a precise fit, a hand reamer is the way to go. You can buy them in exact sizes, or you can get adjustable reamers. We're lucky, the fab shop we use on Ft. Huachuca has a nice set of each, from very small to an inch diameter.
Unread 10-04-2009, 14:52
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Invest in a solid carbide boring bar (assuming you have a lathe). Many are available that you can use on various size holes and get the exact fit you desire. Try EBay, as I have bought some brand new at very low cost. Also make sure the shaft you are fitting to doesn't have a burr left on the edge, as this will give you a false oversize reading on the shaft.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 10-04-2009, 14:54
DonRotolo's Avatar
Back to humble
FRC #0832
If you have a lathe and are willing to take the time to learn how to do precision work, you can use a boring bar to make the hole whatever size you want.
Unread 10-04-2009, 15:37
Elgin Clock's Avatar
FRC #0237 (Black Magic)
A boring bar huh?? As opposed to an exciting bar?
Btw, all kidding aside, according to my drill chart right here the closest drill size to the one you want which are standard ones are either:
the 1/2" one (.500") or a 33/64 (.5156") drill bit.
In metric the closest ones are either:
a 12.50mm (.4921") or a 14mm (.5512") drill bit.
Last edited by Elgin Clock : 10-04-2009 at 15:47. Reason: Fixed the info... all good now!
Unread 10-04-2009, 15:40
Dick Linn's Avatar
no team (Synergy)
I second the boring bar. Boring and reaming are much more accurate than drilling.
On the other hand, how long would it take to run a piece of fine sandpaper on a dowel into the drilled hole while spinning the hub in the lathe?
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-04-2009, 15:46
AdamHeard's Avatar
Lead Mentor
I'd suggest that however you start, end with a reamer.
1/2" shaft is something you'll probably be working with for a long time (And 3/8" for that matter), so you really should get the equipment to make the appropriate hub.
I suggest you actually get a .501 reamer, that's what we use and it works just fine.
Assuming you don't have them already, a .376 reamer and a broach set to put a 1/8" keyway in both 3/8" and 1/2" would be a very good investment.
Unread 10-04-2009, 16:02
Dick Linn's Avatar
no team (Synergy)
You can get an import 12.8 mm drill (.5039) for about 6 bucks if that's not too sloppy for you.
http://www.use-enco.com/CGI/INPDFF?P...PARTPG=INLMK32
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 10-04-2009, 16:03
Bob Steele's Avatar
AKA: Bob Steele
I second...or third...or n... the idea of using a reamer...
Proper fit in a hole is made by using a reamer. You can start the hole with a drill... or bore it out...but the final thousands are taken with the reamer.
Reamers for .5, .375, and .25 should be part of any team's toolkit..
(rather .501/.502...etc) to use with 1/2", 3/8", 1/4" shafts.
If you are looking for press fits... you may have to purchase different reamers that will make the necessary pressfits for your bearings or whatever else you want to press in...
Unread 10-04-2009, 16:41
Alan Ing Alan Ing is offline
None #0368 (Kika Mana)
Alan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond reputeAlan Ing has a reputation beyond repute
As others have mentioned, an oversized reamer is a great way to go. You can definitely bore precise holes using a boring bar, but using a reamer is a bit faster.
I would suggest you get an over / undersized chucking reamer set. Enco's cheapest set is currently $59.95 (china's finest, prefer american, but these have served us well for 6 years). These sets come with 14 reamers (reamers are .001" + and - of standard chucking reamers centered on 1/8" - 1/2" sizes by 1/16th increments)
.124"
.126"
.1874
.1876
.249
.251
.3115
.3135
.374
.376
.4365
.4385
.499
.501
The great thing about an over/under size set, is that you can use the undersize reamers for pressing fitting pins and shafts (some bearings) and use the oversize ones for slip fits.
Also get a standard size reaming set from 1/8" to 1/2".
While we are talking about reamers, other useful reamers that we use for FRC include .874", .875", 1.124" and 1.125" which really help if you want to install 3/8" and 1/2" ID flanged bearings like the ones used in Andymark gear boxes. We use these all the time and make life a whole lot easier. Since these reamers are on the large size, we have had to turn down the shafts so a standard 1/2" chuck or a 3/4" collet could fit them.
I think we also have a .315" reamer which we use if we are installing custom gears to a CIM motor. remember, the shaft on a CIM is metric 8mm (.315) not 5/16" (3.125). Probably would be better if we had a .316" reamer.
Remember, these reamers can be used in a lathe or a mill.
Typically we bore or drill hole sizes about 1/64th" smaller and then ream them to fit. Do not run the reamer at typical drill speeds. Run them much much slower and with lubricant for best results.
Unread 10-04-2009, 16:46
Oh, one last thing. Make sure the pulley, wheel, hub or whatever slides over the shaft before you final broach it. Can't use a straight reamer to open up the hole once it is broached although a spiral one might work if you can find one.
Unread 10-04-2009, 22:13
JesseK's Avatar
FRC #1885 (ILITE)
These are great responses guys; I'll look into the offseason tooling budget to get what we need. Thanks!
GitHub
Unread 10-04-2009, 22:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A letter "O" drill or reamer is this size. I've drilled or reamed CIM pinions to letter O size for the past several years, and it works well.
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Leftover 1/2" Drill Motor Mounts JAlpert General Forum 0 23-11-2003 20:53
A Summer Event (or, 345 or 502 Horsepower, Take Yer Pick) archiver 1999 0 23-06-2002 23:18
