Go to Post keep making a difference out there everyone...slowly but surely everyone will catch onto FIRST and then the world will be a better place :) - tiffany34990 [more]
Unread 11-04-2009, 03:58
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Re: 0.502" Drill bit?
Question.....What material is the shaft? If it's aluminum, it will tend to be barely just too big. Steel .5" shaft fits perfectly though....at least that's my experience. I got a flywheel machined and tried to put it on a .5" aluminum shaft and it barely wouldn't fit. So I took it to home depot to try and find another aluminum shaft that might fit (different batch, right?). All of them gave the same result. So I tried the steel shaft, and it fit perfectly.
I'm a mentor looking for a home in Southern California! I know Java, C++, electrical and mechanical.
Need Java or C++ help? Send me a PM!
Unread 11-04-2009, 04:17
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The two shafts are made with different tolerances.
Standard 0.5" aluminum extruded round will be somewhere in the range of +-0.005" on the diameter. It's never going to be 0.500" even. You would need precision ground shaft. Even with precision ground shaft, you could have anything from 0.500" to 0.4998" (for example, using McMaster standards). If it's 0.500" even, it's not going to go into a 0.500" hole.
The tolerance on steel round stock is generally +0 and minus a few thousandths, leading to your shaft fitting nicely into a 0.500" hole.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-04-2009, 12:18
Dick Linn's Avatar
no team (Synergy)
Team 975 once had to hone out a pair of 5/8" bore flanged steel sprockets to fit a 16 mm shaft. I figure it was probably .004" or so. We used a 5/8" shaft in a drill press and a lot of valve grinding compound. It took a lot of time but the fit was beautiful. Next time that was needed, we just spun the shafts and sanded them down to fit. Much easier.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Championship Event - Where the "Random" Match Sorting Really "Shines" Travis Hoffman Championship Event 57 19-04-2007 08:06
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Leftover 1/2" Drill Motor Mounts JAlpert General Forum 0 23-11-2003 20:53
A Summer Event (or, 345 or 502 Horsepower, Take Yer Pick) archiver 1999 0 23-06-2002 23:18
