#16
Re: 0.502" Drill bit?
Question.....What material is the shaft? If it's aluminum, it will tend to be barely just too big. Steel .5" shaft fits perfectly though....at least that's my experience. I got a flywheel machined and tried to put it on a .5" aluminum shaft and it barely wouldn't fit. So I took it to home depot to try and find another aluminum shaft that might fit (different batch, right?). All of them gave the same result. So I tried the steel shaft, and it fit perfectly.
#17
Standard 0.5" aluminum extruded round will be somewhere in the range of +-0.005" on the diameter. It's never going to be 0.500" even. You would need precision ground shaft. Even with precision ground shaft, you could have anything from 0.500" to 0.4998" (for example, using McMaster standards). If it's 0.500" even, it's not going to go into a 0.500" hole. The tolerance on steel round stock is generally +0 and minus a few thousandths, leading to your shaft fitting nicely into a 0.500" hole. |
#18
Team 975 once had to hone out a pair of 5/8" bore flanged steel sprockets to fit a 16 mm shaft. I figure it was probably .004" or so. We used a 5/8" shaft in a drill press and a lot of valve grinding compound. It took a lot of time but the fit was beautiful. Next time that was needed, we just spun the shafts and sanded them down to fit. Much easier.
| Championship Event - Where the "Random" Match Sorting Really "Shines" | Travis Hoffman | Championship Event | 57 | 19-04-2007 08:06 |
| New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" | Jessica Boucher | Team Organization | 0 | 10-08-2005 10:55 |
| "Thunderbirds" Vs. "Team America" Which one will rule the box office? | Elgin Clock | Chit-Chat | 3 | 07-09-2004 19:53 |
| Leftover 1/2" Drill Motor Mounts | JAlpert | General Forum | 0 | 23-11-2003 20:53 |
| A Summer Event (or, 345 or 502 Horsepower, Take Yer Pick) | archiver | 1999 | 0 | 23-06-2002 23:18 |
