Go to Post You can't expect a situation to get better if you don't make an attempt to confront it. - AndyB [more]
Unread 10-04-2009, 12:01
Burmeister #279's Avatar
Burmeister #279 Burmeister #279 is offline
What Time Is It?
AKA: Nick Burmeister
FRC #0279 (TechFusion)
Burmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of lightBurmeister #279 is a glorious beacon of light
Send a message via AIM to Burmeister #279
Team 279's 2009 Code [LabVIEW]
I've finally been able to post the code from this year
We only used the Basic Robot Main file from the Basic Project and did not use the independent autonomous file so i'm not going to post the whole project file. The Atlanta code is fully commented and there is a sub VI called autonomous matrix that is also in the zip file that is used in the code.
[edit]
The Basic_Robot_Mode vi was changed to include the robot mode variable output.
[/edit]
[edit2]
The buckeye code was thrown together from scratch thursday night at the regional because our code that we had made didn't work so it looks pretty terrible =)
[/edit2]
[edit3]
Feel free to use the code in presentations or in an educational fashion but please say its from Team 279.
Buckeye Code and Commented Championship code is in Buckeye_and... .zip, uncommented version of championship code in 279_Atlanta... .zip
[/edit3]
WHAT TIME IS IT? TWO SEVEN NINE!!! [Team B =) ] Awards: 4 Safety, 2 Ind. Design, 2 Xerox, 1 Nat. Champs
2009 Buckeye Semi-Finalists (1014 & 695) || 2008 GLR Safety Award || 2006 GLR Safety Award
2005 Buckeye Regional Champs (67 & 274) & GM Industrial Design Award & Safety Award GLR Quarter Finalist & Xerox Creativity Award & Safety Award National Xerox Creativity Award & Curie Quarter Finalist (1126 & 180)
2004 Buckeye Delphi Driving Tomorrows Technology Award & Quarter Finalist GLR Champs Nationals Curie Division Finalist
2003 GLR GM Industrial Design Award || 2001 National Newton Division Winner & National Champions
2000 MI DaimlerChrysler Team Spirit Award
Unread 10-04-2009, 14:27
jacobhurwitz jacobhurwitz is offline
FRC #0449 (Blair Robot Project)
jacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura aboutjacobhurwitz has a spectacular aura about
Re: Team 279's 2009 Code [LabVIEW]
Cool, thanks! I hope more teams start posting code, too.
Unread 10-04-2009, 15:34
What Time Is It?
I agree, though there are two sides to this. In the competition, traction control (though it hasn't been proven beyond reasonable doubt) could be a huge advantage to robots that have it, and providing the code to do it would be gracious but sometimes the code is pure-custom and giving it away for anyone to use... i just don't think many would be up to that
Unread 10-04-2009, 17:49
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
May I ask, what are you using the matrices for? How is it being used?
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 10-04-2009, 18:23
What Time Is It?
Of course you may ask, that's why i posted it =). They are being used in our autonomous system. The system was developed by a teammate to take the autonomous time (the unbundled variable at the top of autonomous enabled) and compare it to the first column numbers. Each of those numbers is a point where we want the drive direction/speed to change. The second and third columns are, respectively, the X and Y values that we want to change to.
The time values are in seconds, between 0 and 15.
X and Y are values between -1 and 1 which simulates the joystick input to the Arcade drive VI
In order to switch between the 12 matrices, there are 6 switches on the driver station that are added as can be seen in Autonomous Disabled to derive which matrix is to be used. The matrices on the front panel are labeled for each position they will be used in. The programming team debated over what to do with an unwanted combination and decided that it would do exactly what we did at Buckeye: Go forward.
if you would like to know anything else or if i missed something, please don't hesitate to ask.
Unread 11-04-2009, 09:48
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
One big advantage of releasing your code (IMHO) is that you're able to take whatever is released and use it the next year due to the rule about COTS software. This is a particularly useful thing if you create a library out of useful generic things that aren't specific to a particular robot. Granted, one could easily recreate a lot of things, but that just seems like wasted work.
Unread 11-04-2009, 11:22
What Time Is It?
Libraries would work for the teams who write the code in C, however, we used LabVIEW and only the autonomous uses a custom VI and even that is quite small and easy to reproduce. The entire Buckeye Regional program we used was redone in <30minutes do to a massive fail on my part. Definately easy to reproduce, granted we didn't use a camera nor any special sensor driven processes [traction, robot avoidance, etc.] which would take longer, but either way, As i said before, releasing code would be nice but not all teams are going to.
Unread 11-04-2009, 12:30
virtuald's Avatar
RobotPy Guy
True, if you don't modify the default stuff extensively, then there isn't much advantage of releasing stuff. But for anyone who did, I would say its a bigger advantage (we had 4 independently steerable wheels, so the default code didn't work particularly well for that.. ).
Of course, we did ours in C++... but I think LabView allows you to create reusable components, so thats probably roughly equivalent to a library.
Unread 11-04-2009, 15:05
What Time Is It?
It definately would help you guys more than us. our autonomous stuff is the only advanced work that would help us but it was easy to redo. are you guys going to put your code up?
Unread 11-04-2009, 17:52
virtuald's Avatar
RobotPy Guy
It is up. See my signature.
Of course, I haven't actually put up a separate notice on Chief Delphi, but maybe I will at some point.
Unread 11-04-2009, 22:23
What Time Is It?
Ah I see. You should post here, it's more visible =)
Unread 11-04-2009, 23:56
virtuald's Avatar
RobotPy Guy
Ok, you've convinced me: http://www.chiefdelphi.com/forums/sh...360#post849360
Unread 12-04-2009, 17:05
What Time Is It?
Sweet. hopefully more people will post theirs too.
Unread 13-04-2009, 21:28
JasonF JasonF is offline
FRC #2848 (The All Sparks)
JasonF is an unknown quantity at this point
I need to talk it over with the Team Coach, I will probably release some of our code. Its a Crab Drive system, so I consider it pretty interesting.
Will look more in depth at your code once the finals are over.
But the Matrices sounds like an interesting approach to the Autonomous Commands
Rookie Year is keeping us busy for sure!
Unread 14-04-2009, 15:31
What Time Is It?
did you use LabVIEW or C++?
2009 Team 1511 LabVIEW Scouting Database Larry Lewis Scouting 22 20-01-2010 23:47
Team 449 LabVIEW 2009 Code jacobhurwitz Programming 6 03-04-2009 20:23
custom C/C++ code in LabView? Pneumaticsman NI LabVIEW 5 14-01-2009 23:05
Team 39, 2008 LabVIEW Beta Code BornaE General Forum 17 10-10-2008 17:21
pic: Team 279's 2008 Robot jimsmith2354 Extra Discussion 9 25-02-2008 20:39
