Go to Post I'm sure they liked the size and power output but disliked when they were on fire. - notmattlythgoe [more]
Unread 13-04-2009, 21:43
JasonF JasonF is offline
FRC #2848 (The All Sparks)
JasonF is an unknown quantity at this point
Re: Set Digital out
Maybe I am not understanding the question completely
But If you have an Array of data already that is changing Simply use a "Replace Array Subset", set the index to 7 (DIO 8 on the DS) and the new element to True or False. This will leave the rest of the data in the Array untouched, changing only the 1 element
Other wise build your array with Boolean Values. Using the Set DIO DS VI drop a "build array" In, expand it to 8 Elements (0-7) and then use Constants on the Last Output and whatever outputs you are not using for False. Then pass your data into the Outputs that fluctuate.
I Hope this helps, if not send me a message or something, I have been working on the DIOs for the past couple days...
Jason
Unread 13-04-2009, 22:01
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
Re: Set Digital out
Make sure that when you do this, you use a shift register or feedback node so the array values are retained for the next iteration
-- Marshal Horn
Unread 13-04-2009, 22:19
Re: Set Digital out
Good point,
Thanks for the catch
Sorting out Digital NASA TV Billfred General Forum 2 03-12-2007 18:55
pulsing digital out pins, not as fast as pwms Generalx5 Programming 5 02-04-2007 18:52
Digital out signal speed on off, almost like PWM but at max 60Hz Generalx5 Electrical 2 27-03-2007 12:26
Set Default Digital inputs to Low? How? bad Analog value? Generalx5 Programming 11 04-01-2007 18:57
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
