Go to Post You can't unwind after build season knowing that competition season is just around the corner! ;) - Hallry [more]
Unread 15-04-2009, 00:03
Looking Forward Looking Forward is offline
Honest Analysis
Rookie Year: 1992
Looking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond reputeLooking Forward has a reputation beyond repute
Predictions Championship 2009: Galileo
No division is as rich with history and storied teams as Galileo. After crowning the 2008 Champions, Galileo is now reloaded with more storied veterans than any division, boasting former Champions and some of the all-time greats. 12 previous FIRST Championships, and many more Einstein appearances, are represented by this division.
Yet, for all the talent and tradition at the top, this division also has the weakest bottom end. A number of teams here struggled in regional competitions, and that will mean easy targets and uneven matches during qualifications. Even the elimination field could thin out by the 24th pick more than other divisions (though it will still take a very solid machine to be selected into the elimination rounds). It will take consistency, good strategy, and a favorable schedule to emerge as the #1 seed in this division.
PREDICTIONS:
TIPS:
They haven't lost a match all year, and are the only team that can say that. 971 was the undefeated #1 seed at SVR, though they did have three ties. With the aid of 254, they captured gold. They're a solid scoring machine, but aren't overwhelming on their own. They should be in the eliminations, but it would be very surprising to see them earn a medal.
Wildstang won their home event in Chicago, but was swiftly eliminated in the Boilermaker quarters. 111 hasn't returned to Einstein since they won the Championship in 2003, but they have a strong bot that is capable of scoring very effectively. Expect 111 to be a member of one of the top four alliances, but how far they advance will be hinged on their partners and opponents.
Trinity was unable to pick up a regional victory this year to go with the two they won last year. But 40 reached the finals at both events they attended, BAE and Chesapeake. Checkmate is a solid shooter, with a swerve drive that makes them hard to contain and helps them worm their way into and out of sticky situations. But their biggest strength is their autonomous, which will often score several balls. They're not the type of team to carry an alliance, but they can be a solid component to an elimination alliance.
987 has one of the more distinctive shooters, and it is very effective on the field. The Las Vegas champions are going to be dangerous, but their slightly smaller capacity than the elite will hurt them when facing off. The High Rollers will have to play to their full ability the entire tournament if they want a high seed, and will otherwise be at the mercy of the alliance selection.
1318, 1332, 1250, and 744 should all factor into the elimination rounds. Issaquah has the most upside, and their autonomous scoring gives them a weapon that few other teams have. SWIFT isn't the prettiest robot, but they get the job done (and won two regionals because of it). The Gator Bots have won individual matches against the combination of HOT and the Thundchickens at two events, but lost to them in the eliminations at all three Michigan events they attended. They're solid, but need support in order for them to maximize their potential. Shark Attack has the ability to score with anyone when left alone, but they're troubled by defense. One or two of these teams could potentially go deep, but the rest will likely lose early on.
DARK HORSE:
If you had to guess teams that have put up scores like 121 and 141, The MeTool Brigade probably wouldn't be the first one named. 1208 has a solid scoring machine and is an excellent empty cell running machine. It's no mistake they won Kansas City and seeded 2nd in St. Louis. There's a chance they could miss the eliminations totally, but would be a solid fit in the right alliance as a 2nd round selection.
SLEEPER:
The MidKnight Inventors are as explosive as any team out there, but have also been shut down and scored on when things don't go their way. 1923 can score a bunch quickly, and is capable of playing with empty cells, but they've also been abused by physical defense. They'll likely seed in the middle portion (just like in NJ and Philly), but on the right alliance they could be a great weapon. It certainly doesn't hurt that their coach was on the same alliance as 67 last year, which reached the Einstein finals.
LOCKS:
Nobody has ever played as many matches at HOT has this season. They already have an earth-shattering 63-6-1 record, including a 24-2 record in elimination matches. 67 wants to add 10 more elimination wins to their resume, become the first team to ever win FIVE events in a single season, and notch up their second Championship. HOT is both consistent and explosive, with the capability to score lots of balls very quickly while being very hard to defend for extended durations. The most accomplished team this season, it would be very surprising if HOT didn't leave with a medal.
D'Penguineers use their shooter better than most, and that gives them a huge advantage over many teams and makes them very difficult to stop. 1717 has the ability to drain shots up close (like 1114 and 1771), and that's their ideal method of scoring. They have scored on moving targets and while pinned in less than ideal scenarios, and their swerve drive helps them create opportunities. Their ability to generate offense in all scenarios gives them aspects to their game few other teams can match.
The Technokats haven't been this good in a long time. 45 won DC in convincing fashion and was an unfortunate super cell away from picking up their second win in Indiana. Their giant propeller aids them in keeping their victims still while they score and accelerating quickly, but they are not immune to smart defensive efforts. They can't dump quite as quickly as some of their contemporaries, but their consistency and reliability make them very dangerous. If they can get a partner as capable as 234 (who they paired with at both regionals), they should be playing deep into the eliminations.
Beatty has never gone this long without a Championship before. 2004 was the last time 71 won a Championship, though they were within six points of their fifth in 2007. Team Hammond collected a gold in St. Louis and have a fearsome scoring machine again this year. They have a swerving drive with innovative fan propulsion and a massive hopper. Never bet against the Beast.
Unread 15-04-2009, 00:29
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
Re: Predictions Championship 2009: Galileo
744 got mentioned by someone other than 79! There ya go Alex, well deserved 744
Unread 15-04-2009, 00:33
Brad Voracek Brad Voracek is offline
.999~=1
FRC #0399 (Eagle Robotics)
Brad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of lightBrad Voracek is a glorious beacon of light
Send a message via AIM to Brad Voracek
Congrats 1717, you guys consistently have an amazing robot, and play amazing strategy, with new drivers and a new build team every year (little known fact). But you guys manage to do amazing, and are now a Lock on Looking Forward's list. I can't wait to see you guys on Einstein, you deserve it, and everyone on Galileo needs to look out.
.999~ (Repeating) is equal to one (1).
Team 399 - Eagle Robotics
Unread 15-04-2009, 00:45
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
leaving out 1902 as a sleeper? They are going to be an amazing 3rd pick for some alliance who happens to be paying attention
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
Unread 15-04-2009, 00:47
People need to watch out for 179 as well. I predict they'll be on a new level in Atlanta.
Unread 15-04-2009, 00:52
LBseale's Avatar
LBseale LBseale is offline
Still love 1717
FRC #1923
LBseale will become famous soon enough
Thank you very much for your kind words Team 399 and Looking Forward. We are a brand new team this year (as with every year), and I wondered at the beginning how we would be able to to compare to last year's team. They fell to clearly the best team last year (1114), so I didn't think we could do much better.
It is a great honor to be named a LOCK among teams with such tiny numbers. I just hope we can live up to these grand predictions. Team 1717 is very excited to go to Atlanta and see all the legendary teams there. You won't see us again afterward though, next year's team will have to make it by themselves
399, I remember watching your scissor lift as a Junior in San Diego. Your robot this year is efficient and deadly with spectacular driving. Congratulations on a well-deserved win in Colorado. This year at LA was a lot of fun, and I will make sure to tell next year's juniors about the love we have for our orange friends from Lancaster.
Unread 15-04-2009, 00:59
AdamHeard's Avatar
Lead Mentor
You guys have been a lock every since since 07 (I know you weren't at champs in 07). really. You guys are great.
Unread 15-04-2009, 01:13
Your team has been one my favorites since early last year and I think this thread attests to how many others look up to you. And as Sean pointed out to me in that thread as well, your 07 bot was sick stuff too.
http://www.chiefdelphi.com/media/photos/31533
Can't wait to play against/with you guys!
Unread 15-04-2009, 02:18
andrewhsu's Avatar
andrewhsu andrewhsu is offline
Alumni, College Student
AKA: Andrew Hsu
FRC #1717 (D'Penguineers)
Team Role: Student
andrewhsu is an unknown quantity at this point
Thank you all for the wonderful comments. We're all so excited about the upcoming competition, and hope to see all of your great robots there as well.
On a side note, no mention of Team 56?
Team 1717
2009 Championship Motorola "Quality Award"
2009 Championship- Galileo Finalists
2009 Sacramento Winner
2009 Sacramento Motorola "Quality Award"
2009 Los Angeles "GM Industrial Design" Award
2009 Los Angeles Finalist
2008 Championship-Galileo Finalists (2nd Seed)
2008 Los Angeles Winner
2008 San Diego Winner
2008 Los Angeles Delphi "Driving Tomorrow's Technology" Award
2008 San Diego Delphi "Driving Tomorrow's Technology" Award
2007 San Diego Finalist
2007 San Diego Imagery Award
2007 Los Angeles Semi-Finalist
2006 Los Angeles Rookie All-Star
Unread 15-04-2009, 09:13
AKA: Jonathan
no more than they need to watch out of 20, 973, 25, 65, 11, 47, 359, and all those new rookies who decided to show us they know how to build a robot.
Unread 15-04-2009, 12:29
qwezzen qwezzen is offline
qwezzen is an unknown quantity at this point
Team 704 is an underdog but has a lot of potential. Since they have not been to the Championships before, they will most likely be overlooked. But they have a lot to bring to the winning alliance.
Unread 15-04-2009, 18:12
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
973 will also be a force to be reckoned with. Can't wait to see how it all unfolds on Saturday.
Unread 15-04-2009, 20:24
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
And they deserve it, they were AWESOME in Florida.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 19-04-2009, 15:30
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
TIPS:
Very surprising indeed
Unread 19-04-2009, 18:39
EdwardP's Avatar
EdwardP EdwardP is offline
Team Role: Tactician
EdwardP is a jewel in the roughEdwardP is a jewel in the roughEdwardP is a jewel in the roughEdwardP is a jewel in the rough
Definitly not how we expected it to happen, but we'll take it!
Predictions Championship 2009: Archimedes Looking Forward General Forum 18 16-04-2009 06:11
Predictions Championship 2009: Curie Looking Forward General Forum 10 15-04-2009 14:26
Predictions Championship 2009: Lunacy for Lunacy Looking Forward General Forum 34 14-04-2009 22:49
Predictions Championship: Galileo Looking Forward General Forum 30 19-04-2008 23:40
