Go to Post Thank you FIRST -- thank you, thank you, thank you -- I can't say that enough. We can't say that enough.... Its too bad that more of us don't try. - Aidan F. Browne [more]
Unread 15-04-2009, 15:03
CHSboy CHSboy is offline
FRC #2153
CHSboy is an unknown quantity at this point
Dashboard
Could someone tell me how you set up the dashboard for the axis camera? We didn't use it when we competed, and I don't really know how to set it up so that I can get live feed from the axis camera.
Unread 15-04-2009, 16:03
Re: Dashboard
Can you elaborate on what problems you're having after Greg's response in your previous thread? http://www.chiefdelphi.com/forums/sh...ad.php?t=76128
Unread 17-04-2009, 15:19
FRC #2153
Re: Dashboard
I need to check on things. I switched laptops and I'm thinking that it's confused with the data. I'll see if it continues after I sort things out.
Unread 20-04-2009, 09:33
FRC #2153
Re: Dashboard
I've decided I'd go back to the other laptop. It's not worth the time sorting things out even though I could work faster on a different one. Do the dashboard defaults automatically give you live feed, or do you have to tweak things a bit, and if so, how would I go about that?
~CHSboy
Unread 21-04-2009, 09:05
Re: Dashboard
The robot template code automatically waits for a TCP session to send data to on a dashboard. When the dashboard connects to the other side, the images will start flowing.
The dashboard has a button on its lower left corner that controls the display. I don't remember whether it defaults to on or off, but that is all that is required to control it.
Greg McKaskle
Dashboard Eugene Fang Programming 4 24-04-2007 21:37
Labview Dashboard and updated IFI dashboard spec Joe Ross LabView and Data Acquisition 1 04-04-2006 02:04
2004 Dashboard Protocal vs 2005 Dashboard Protocal Kyle T Programming 4 14-03-2005 22:19
Dashboard Kevin Karan Programming 60 19-03-2004 21:53
dashboard archiver 2000 1 23-06-2002 23:06
