Go to Post FIRST Isn't just about the robots, it's about Gracious Professionalism, co-opetition, and outreach also. - Julia Magoolia [more]
Unread 15-04-2009, 22:41
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
Portable Windriver
Has anyone made, or know how to make a portable windriver?
The reason being is I want to use it on a portable hard drive and just store the workspace on that for next years season so anyone can take it home and work on it and it can be moved to any computer.
Unread 16-04-2009, 11:19
virtuald's Avatar
virtuald virtuald is online now
RobotPy Guy
AKA: Dustin Spicuzza
Re: Portable Windriver
I would imagine that due to licensing constraints, this isn't possible. An alternative is to install WindRiver in a virtual machine, and move it around in that. Of course, at that point Windows will complain about its licensing... (unless you have a corporate license for it).
Unread 16-04-2009, 11:21
virtuald's Avatar
RobotPy Guy
But on that thought, if you're just wanting to share the workspace, then using a version control system like SVN would be ideal -- then the members of your team would be able to access the workspace from anywhere in the internet (assuming the server is on the public internet -- doesn't have to be). subclipse integrates nicely into Wind River, and allows you to import/export projects seamlessly. Theres a bit about subclipse in the FRC C++ Programming Guide...
Unread 20-04-2009, 20:19
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
Moving around a VirtualBox virtual machine worked great for our team. It's mostly just drag and drop, and saves massive time for installation of Wind River and LabView, et al.
Plus being able to save machine state is invaluable. I'd highly recommend teams with a technical background to give it a whirl; the first few days were excruciating trying to find a fast way to get the build environment on multiple laptops and workstations. You can't beat transferring an already-configured machine over the network
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 20-04-2009, 21:01
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
Can you post any links on how a team would go about setting up WindRiver for SVN?
Unread 21-04-2009, 20:50
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
install subversion (http://subversion.tigris.org/getting.html#windows)
run (in cmd) svnadmin create C:/Documents and Settings/longcomplicatedpath/repository
(yes, you must use / instead of \ for the path)
install subclipse (look in C Programming guide)
open SVN Repository View
Right click in SVN Repository view, New> Location... (or something like that)
enter file:///C:/Documents and Settings/longcomplicatedpath/repository
hit ok (if you get an error, tell me what it says)
with your project, Right click>Team>Add to repository (something like that)
more info at http://svnbook.red-bean.com/en/1.5/svn-book.pdf and in the WRWB help file
Watchdog.Kill();
Unread 23-04-2009, 00:29
AKA: Josh
can you explain the part about creating the repository or point me to a link? i tried typing svnadmin create[...] in cmd but it doesnt recognize it
Unread 23-04-2009, 22:39
byteit101's Avatar
first, did you install subversion?
did it fail or succede?
then open cmd and type svnadmin create C:/dir/.../...
look in http://svnbook.red-bean.com/en/1.5/svn-book.pdf on page 40, the first line of command and page 31 near the bottom about windows paths
Watchdog.Kill();
Unread 24-04-2009, 02:16
AKA: Josh
OK, so i created the repos and have created users and put them into different groups. i tried the url, got the certificate, but i am not able to log into it from remote computers, do i have to set some type of permissions or use the ip address?
I just need to be able to access the repo from different computers.
Unread 24-04-2009, 22:36
byteit101's Avatar
you need to install apache (at least that is how i could only get it to work)
just google apache, download and install 2.2
(fromhttp://www.codeproject.com/KB/winsdk/SubversionApache.aspx)
When the installation is finished, go to the bin directory within the Subversion installation, find two files with extension *.so, and put them into the (Apache)/modules directory. The files are mod_authz_svn.so and mod_dav_svn.so.
Go to the conf sub-directory within the Apache installation directory and open the httpd.conf file in any text editor.
Add the following lines:
LoadModule dav_module modules/mod_dav.so
LoadModule dav_svn_module modules/mod_dav_svn.so
LoadModule authz_svn_module modules/mod_authz_svn.so
Now assuming your reposotory is at C:\svns\repos1 and you want to redirect localhost/svn to it,
add this to the httpd.conf:
<Location /svn>
DAV svn
SVNListParentPath on
SVNParentPath C:/svns
</Location>
If you get an error, tell me
Watchdog.Kill();
Unread 24-04-2009, 22:40
byteit101's Avatar
once you do that restart apache( or restart the computer), and if that computer's ip address is 192.168.101, on another computr (same network) type in http://192.168.1.101/svn
your web browser, you should see your repository there, now you can access it from other computers
then from windriver, new, project> from svn, new connection to http://192.168.1.101/svn/yourrepoitory
and finish out the dialog.
read the WR help for more details
Watchdog.Kill();
Unread 25-04-2009, 01:07
AKA: Josh
[EDIT] Actually i followed the directions with editing the httpd file, but when i restart apache i get this error message:
Invalid command 'DAV', perhaps misspelled or defined by a module not included in the server configuration
Unread 25-04-2009, 20:48
byteit101's Avatar
did you go to the bin directory within the Subversion installation, find two files with extension *.so, and put them into the (Apache)/modules directory. The files are mod_authz_svn.so and mod_dav_svn.so
also make sure all three lines below are in httpd.conf (and restart apache after you modify it)
If that does not work, copy C:\Program Flies\Subversion\libapr-1.dll and libapriconv-1.dll to (apache)\bin and replace the current ones
Watchdog.Kill();
Unread 25-04-2009, 20:52
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
I think you need WebDAV not DAV. Not sure though
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 26-04-2009, 09:21
byteit101's Avatar
no, you need DAV, but you can have WebDAV if you really want. DAV is part of SVN. DAV is related to WebDAV, but different (I think)
EDIT: I dont have WebDAV on my server, just DAV, and Subversion Works fine
Watchdog.Kill();
pic: 1726 - portable OI TheOtherGuy Extra Discussion 1 07-03-2008 18:53
paper: Portable Inspiration Phil Ross Extra Discussion 2 02-11-2007 11:26
Portable Software Pavan Dave General Forum 17 23-07-2007 09:07
Portable Racks aksimhal General Forum 8 02-05-2007 12:46
Portable IDE Nitinol Programming 14 04-02-2007 03:23
