Go to Post Engineers crave and demand facts, and won't reach a conclusion without them. - Richard Wallace [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 16-04-2009, 07:55
param_vlsi param_vlsi is offline
param_vlsi is an unknown quantity at this point
very urgent help needed regarding algorithm for self balancing of two wheeled robot
Hi,
I am new to this forum and I need urgent help regarding algorithm for self balancing of two wheeled robot.
I am constructing a simple two wheeled robot which will balance on its own
I am using accelerometer for tilt angle calculation.accelerometer will give tilt anagle
Can any body tell me algorithm for balancing this robot with this tilt information.
I am using two dc motors and to control them i am applying PWM wave.
Thanking you in advance.
With regards,
S Param
Unread 16-04-2009, 21:59
DonRotolo's Avatar
Back to humble
FRC #0832
Re: very urgent help needed regarding algorithm for self balancing of two wheeled rob
Wow. That is a very large request. And, not so easily answered.
My recommendation is for you to look at this page of links, and use Google to search the web. That will get you well on your way.
Good Luck.
Don
Unread 16-04-2009, 23:28
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Ok, a quick glance of this makes me think that you need more sensors. Below is a link talking about the segway. It says that there are 5 oscilloscopes in it. I'm no expert, but I think if they could have made it with less, they would have. Just curious, what do you need this for? It sounds kind of cool.
http://www.iit.edu/~ipro340f03/hsw.htm
A last second thought. How are you planning on balancing it when it is off center? Moving a weight or changing wheel speed? I would think that the first could be done a bit easier then the second. Though that really depends on the application.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 17-04-2009, 00:29
I heard that we can balance only with one accelerometer.I am going to balance with controlling the speed of motors.
if you know any algorithm for this let me know
Unread 17-04-2009, 03:08
Molten's Avatar
AKA: Jason
From what I know about dynamics here is a picture of what is happening.
....................................._____________
.......................................\.......... ..C............\
......................<---------- ...\__.|....O.....|_____\
Ok, so basically. The C is the center of mass, O is the center of the axle, and U is the distance between C and O. There is a moment created by gravity anytime that C isn't directly over O. The accelerometer provides you with an angle that can be used with geometry to find the displacement in the horizontal plane. The formula for the moment created is mass*gravity*displacement. Now, you have the amount of torque that needs to be corrected against. The way you plan on fixing this is by adding another moment in the opposite direction created by the movement of the axle. The only way this will work well is if the axle supports the frame with bearings so that the actual turning does not create a torque about the axle. All you want is a push along the arrow marked above. Now, the way to calculate this moment is to use the angle found by the accelerometer and geometry to find the vertical displacement between the axle and the C. This moment is going to be displacement*pushing force. The pushing force is going to be mass*gravity*mu*pi*diameter of wheel*rpm. The rpm may take a sensor of sorts.(not sure on that part) So, in essence:
mass*gravity*mu*pi*U*sin(90-N)*diameter of wheel*rpm=mass*gravity*U*cos(90-N)
I go ahead and cancel the mass, gravity and U. This leaves:
sin(90-N)*diameter of wheel*rpm=cos(90-N)
So, rpm=cot(90-N)/diameter of wheel.
OK, now for the disclaimer: All the math posted above was done at 3 in the morning while watching tv and being half asleep. I am not by any means confident in all of the math I did. I think that it should give you a rough estimate of what you are looking for. Anyone that can confirm or improve my work would be greatly appreciated.
Motor specs for self-balancing scooter dunkonu Motors 1 23-02-2008 12:05
2 wheeled balancing robot John Gutmann Technical Discussion 16 26-08-2005 14:21
Self-Balancing 2 Wheeled Robot Mike Robotics Education and Curriculum 25 02-08-2005 15:12
Self Balancing Robot in FIRST (plausible? possible? preferable?) phrontist General Forum 11 28-06-2004 10:55
Gear Help Needed- Urgent psychoCHIPMUNKK Technical Discussion 6 05-02-2004 13:44
