Go to Post if it was up to me, id just get one of those spinning BINGO things and do it that way - dodar [more]
Unread 19-04-2009, 16:43
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Plastic whiskers on central spindle: Design Secrets Revealed
Now that the season's over, it's time to pry some design secrets out of the top teams.
There were a number of teams that had a central spindle that had plastic whiskers sticking out to move the orbit ball up the hopper.
What did you use for the whiskers? How did you mount them on the spindle? What different materials did you try? How well did they work out? If you had to do it again what would you do differently?
Some teams had a series of beater bars with whiskers, same set of questions: What did you use for the whiskers? How did you mount them? How well did they work out? If you had to do it again what would you do differently?
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 19-04-2009, 16:49
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Re: Plastic whiskers on central spindle: Design Secrets Revealed
We used strip brushes from mcmaster. I believe we went with 3" long "whiskers". We attached them using the mounting strips that mcmaster also sells and just screwing them into our ABS drum. After switching from foam, and later surgical tubing to brushes, our helix no longer had jamming or stalling issues.
I also want to say that we did get the idea for the brushes from 148's video after pausing it and carefully investigating. Before the brushes we were having lots of issues with "dead" spots in our helix, so thanks 148 for posting that video.
Mentor 2415
Unread 19-04-2009, 20:37
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We're too darn lazy and cheap to do something like that (we did find the brushes offered by McM). The students played around with different stuff the first week, and discovered that flaps of shelving liner work pretty well, so we used a couple dollars worth of shelving liner with flat aluminum stock to hold it to the sewer pipe, the shelving liner has a flap about an inch wide on each side of the aluminum. No special ordering of parts....just some drilling and screwing, and it's done.
Unread 19-04-2009, 20:41
gorrilla's Avatar
gorrilla gorrilla is offline
1557 alumni, 4639 mentor
AKA: adam spears
FRC #4639 (RoboSpartans)
gorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant futuregorrilla has a brilliant future
we used pnuematic tubeing with zip ties in the ends.......
works well(never jams)
Adam Spears
Team 1557 2007-2011 student-Lake County FL
Current Team 4639 mentor- Houston TX
Unread 19-04-2009, 21:49
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
One of our mentors works at an 80/20 and pneumatic place so we used pneumatic tubing stuff. Though, we didn't have a central brush. We used them as rollers to take balls in and move them through the track. We used school colors =D
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
Unread 19-04-2009, 22:03
Peter Randall Peter Randall is offline
Director of Technology
FRC #1218 (Vulcan Robotics)
Peter Randall will become famous soon enoughPeter Randall will become famous soon enough
Team 1218 found 4" brushes from PowerBrushes.com fit perfectly into the channel of 1" 8020 and gave us the right diameter for our 24" cylinder. We could alter the number of brushes from 1-4, control the stiffness and length of the brush material and could easily direct drive the 8020 core with a combination of Andy Mark transmission, CIM and a custom adapter. Dead simple, 100% reliable.
Peter Randall
Chairman, Department of Engineering & Robotics
Springside Chestnut Hill Academy
TEAM 1218
Unread 19-04-2009, 22:19
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Our infeed roller used the hook side of Velcro, and it sure worked great.
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 19-04-2009, 23:15
MrForbes's Avatar
AKA: Jim
One of the first things we did in build season was to try different materials on the orbit balls...and quickly discovered that the hook side of Velcro did cause noticable damage to the Spandex covering, so we decided not to use it, to avoid damaging the game pieces, as the rules say.
Unread 20-04-2009, 13:55
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
We used PVC rollers, with pneumatic tubing.
A VERY easy way to secure the tubing was to drill a whole just a tiny bit undersized in the PVC, then run a short fastener into the end of the tubing in the PVC (requires drilling a hole on the opposite side of the PVC to insert the fastener).
Unread 20-04-2009, 16:15
gorrilla's Avatar
AKA: adam spears
alternatively to save a little weight...
just drill a hole in each side at 90' degreee angles and stick the tubing through both(they havent come out of ours at 550rpm)
and to power it easily, if your using 4' PVC just screw a cleanout of the bottom and attach a 1' square tube to a motor and slide everything in place
Adam Spears
Unread 20-04-2009, 19:54
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Team 1468 used pneumatic tubing from the KOP. The central spindle was a 1" square piece of 8020 tubing with holes drilled through it for the tubing. It was actually one long piece of tubing which was threaded continuosly from one end of the 40" long spindle to the other. This gave us loops sticking out of the spindle to push the balls up. We found that this worked out better than having small tubing sticking out. Tapping 1/4-20 threads into each end of the 8020 made it real easy to bolt on bearings to the spindle.
2017 Season; Game Announcer at
SBPLI Long Island Regional
pic: Warbots Spindle Lawry Goldstein Extra Discussion 3 03-02-2008 01:45
Secrets Bill Beatty General Forum 0 17-02-2007 10:41
Team 639 code secrets revealed! probizzle Rumor Mill 5 06-03-2005 18:44
Revealing Secrets sanddrag General Forum 12 06-04-2003 19:45
Chamber of Secrets DaveyPotter144 Chit-Chat 20 22-09-2002 21:57
