Go to Post Sure, it's just a robotics competition, but some of us actually care about the robots... - Karthik [more]
Unread 21-04-2009, 08:12
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
Re: Team 71's 2002 robot
Here's a description of the 2002 game: http://www.team237.com/2002game.html
Here's a good photo of their robot that year: http://www.chiefdelphi.com/media/photos/12168
Their feet were made from filecards. They didn't actually lift the cards, instead they shuffled them back and fourth to move the bot forward. Try it yourself, put a filecard face down on the carpet and try to push it back and fourth. Now imagine a hundred pounds of weight on the card and you can see why nobody could push 71 backwards.
Once 71 had the goals that year could be pushed sideways, but not backwards. You can see it happen in one of the videos I have from 2002, but I don't remeber which one. http://www.students.ccsu.edu/~rodriguezjel/2002/
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 21-04-2009, 08:29
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
What are filecards?
Mens et Manus
Unread 21-04-2009, 08:51
Enigma's puzzle's Avatar
Enigma's puzzle Enigma's puzzle is offline
Strategery
AKA: Matt Brechting
FRC #2075 (Enigma)
Enigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to beholdEnigma's puzzle is a splendid one to behold
I heard from someone that played against that robot that it tracked the middle goal, but if the goal moved then they would only be able to grapple one goal. the middle one. They also said that they developed an auton that would run out to the middle of the field and ram the middle goal in order to throw them off.
Unread 21-04-2009, 09:09
There was no autonomous back then, so no tracking. It was all driver speed and robot quickness.
71 could be beat out to the middle goal, like 180 did, but it was rare.
Here's the national semi, team 71 v team 60. 60 just beats 71 to the goals, but 71 wins out. It was possibly the most anticipated match of the year. http://www.youtube.com/watch?v=lAmAn...eature=related
71 could grab and push as mentioned, 60 could grab 2 goals, lift them off the carpet and spin them around the robot so no one could grab them. Quite impressive when you consider those goals weighed about 180lbs each.
155, teacher: 2011-
Unread 21-04-2009, 14:52
Not totally true. There was no autonomous period--that came in 2003--but I have heard that one particular team did run mostly without driver control. There were targets on the goals that sensors could see.
Remember, you don't have to have an autonomous period to be autonomous. You can run the entire match autonomously.
Unread 21-04-2009, 15:05
Tim Baird's Avatar
Tim Baird Tim Baird is offline
Design Ninja
FRC #0126 (Gael Force)
Tim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond reputeTim Baird has a reputation beyond repute
Send a message via AIM to Tim Baird
Tis true. The mast in the center of the goals had retroreflective tape on them that played horrible games with pretty much any photographer using flash...
But not many teams used them for their intended tracking purposes.
Tim Baird
FRC Alum and FRC/FLL Volunteer
Project Engineer @ Nypro
History:
Gael Force 126: 1999-2000
WPI 190: 2001-2004
Gael Force 126: 2005-2010
Event Volunteer Only: 2011-Present
Unread 21-04-2009, 08:55
in between teams
AKA: Luke Van Oort
Originally Posted by Ice Berg View Post
What are filecards?
They're kind of like the metal brushes you use to clean a grill. The name comes from their use - cleaning files.
Team 1219: 2009 - Mentor
Unread 21-04-2009, 08:58
Tim Baird's Avatar
Design Ninja
What are filecards?
Filecards are used to clean files, and have many small metal teeth/fingers. Try sticking one into a carpet sometime and pulling. Good luck moving it.
We (190) used them as well, but as anchors. The robot would drive in between two goals, latch on with cables/hooks and drive past into our zone. The anchors would push down into the carpet, raise the drive wheels, and then pull the goals back. It was literally impossible to move the robot. I had always hoped to go head-to-head with 71 to see if they could move us without ripping a hole in the carpet underneath one/both of our robots, but we never met up on the field.
Tim Baird
History:
WPI 190: 2001-2004
Unread 21-04-2009, 09:39
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
The only way to move the goals 190 hung onto was to literally rip the robot in half. Didn't that happen at Battlecry that year?
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 21-04-2009, 09:43
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire)
We (311/308/180) faced 190 in the first round of the eliminations that year.
Unread 21-04-2009, 10:02
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
Taking some personal time
At the Midwest regional that year my team, 93, beat them to the center goal by about 1 sec and rammed it into them lifting the top of their robot into the middle of the two platforms lifting all their wheels of the ground causing them to not move the rest of the match. We ended up winning the match, I've never heard a crowd cheer louder in all my years since, when that happened.
2012-2016 Wave Robotics Team 2826
Unread 21-04-2009, 20:15
Kevin Kolodziej's Avatar
Kevin Kolodziej Kevin Kolodziej is offline
Operator in 100+ matches
AKA: Yngwie Kamen's roadie
Kevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond reputeKevin Kolodziej has a reputation beyond repute
Send a message via AIM to Kevin Kolodziej
You guys hit us so hard that the goal was embedded in the front plate of our robot by a good quarter inch. It took three of us to pry it off I believe.
In the second match of the Einstein finals, SPAM beat us to the center goal and our arms missed the outer goals. We were left without any goals and that robot was not designed to do anything more than move forward fast and then move forward slow. I tried to do what I could to turn the robot and the intent was to push the goals and all robots into our endzone, but that never happened as an axle got bent as our robot got smashed against the side rail. We sat the third match as 173 and 66 finished what we had started.
Ah the good old days
Team 71: 1999, 2000 (Driver), 2001-2002 (Driver, Animator) // Team 1064: 2003 (Co-founder, Coach), 2004 (Coach) // Team 1714: 2006-2007 (Mentor, Coach)
Team 1675: 2005-2007 (Mentor, Coach), 2008 (Mentor), 2009-2017 (Mentor, Coach)
FLL: '04 (Judge), '05 (Ref), '06 (Ref), '07 (Ref), '08 (Judge, Ref), '09 (Judge), '10 (Ref), '16 (Judge Advisor) // Ref: '05 (IN, IRI), '06 (IN, IRI), '07 (IN, IRI), '08 (WMR, Curie)
WI RPC: 2006 - 2016 // FRC Inspector: '07 (WI), '08 (WI, IL), '09 (WI, IL), '10 (WI, CMP), '11 (WI, IL, CMP), '12 (WI), '13 (Northern Lights)
2007 WI Woodie Flowers Award Finalist // 2011 Wisconsin Regional Outstanding Volunteer // 2011/2013 Midwest Regional Chairman's Award
Unread 21-04-2009, 20:18
Ice Berg's Avatar
Seth Berg
AKA: Seth Berg
Kevin,
could you describe how the walking/shuffling mechanism was designed/how it worked?
Mens et Manus
Unread 21-04-2009, 20:21
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Thanks for clearing up what actually happened Kevin. I know from our vantage point at the time we could not actually see much of the match.
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 22-04-2009, 14:06
I found another video that I had on my laptop from 2002, so I uploaded it to YouTube. It is of the Midwest Regional finals. There is a great closeup of the walking filecards from 0:23 to 0:27.
http://www.youtube.com/watch?v=h4slvnvPHW8
Palm OS 2002 Robot Database by Team HEATWAVE Paul Dickman Scouting 11 20-04-2002 23:19
Palm OS 2002 Robot Database by Team HEATWAVE Paul Dickman Championship Event 4 18-04-2002 21:51
Team 71's Updated Web Site Joe Pernick General Forum 0 20-02-2002 00:49
2002 Team 217 ThunderChickens Robot Edward Debler Robot Showcase 6 17-02-2002 02:55
