Re: Team 71's 2002 robot
I heard from someone that played against that robot that it tracked the middle goal, but if the goal moved then they would only be able to grapple one goal. the middle one. They also said that they developed an auton that would run out to the middle of the field and ram the middle goal in order to throw them off.
71 could be beat out to the middle goal, like 180 did, but it was rare. Here's the national semi, team 71 v team 60. 60 just beats 71 to the goals, but 71 wins out. It was possibly the most anticipated match of the year. http://www.youtube.com/watch?v=lAmAn...eature=related 71 could grab and push as mentioned, 60 could grab 2 goals, lift them off the carpet and spin them around the robot so no one could grab them. Quite impressive when you consider those goals weighed about 180lbs each. |
Remember, you don't have to have an autonomous period to be autonomous. You can run the entire match autonomously. |
Tis true. The mast in the center of the goals had retroreflective tape on them that played horrible games with pretty much any photographer using flash...
But not many teams used them for their intended tracking purposes. |
| Palm OS 2002 Robot Database by Team HEATWAVE | Paul Dickman | Scouting | 11 | 20-04-2002 23:19 |
| Palm OS 2002 Robot Database by Team HEATWAVE | Paul Dickman | Championship Event | 4 | 18-04-2002 21:51 |
| Team 71's Updated Web Site | Joe Pernick | General Forum | 0 | 20-02-2002 00:49 |
| 2002 Team 217 ThunderChickens Robot | Edward Debler | Robot Showcase | 6 | 17-02-2002 02:55 |
