Go to Post I've worked with space based navigation and lever arms and planes and Kalman filters. .. and I have never, ever once considered looking up to navigate. - purduephotog [more]
Unread 21-04-2009, 09:05
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
paper: Cyber Blue 234 Belt vs Chain Technical Evaluation
Thread created automatically to discuss a document in CD-Media.
Cyber Blue 234 Belt vs Chain Technical Evaluation by Chris Fultz
This is the presentation package from Team 234's Presentation at the Championship Forums on "Belt vs. Chain" for FRC drive systems.
The presentation was given by students Jamie Cartwright, Miranda Goelz, Phil Welsh and Mentor Collin Fultz.
Unread 21-04-2009, 17:36
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: paper: Cyber Blue 234 Belt vs Chain Technical Evaluation
Interesting... I wonder if this all would hold true with 25 chain... I would def. consider belts next year, but they are a bit harder to assemble and take up a bit more space... Cool presentation!
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 21-04-2009, 19:05
Rookie Year: 1942
our plan is to repeat the testing and duplicate the parameters, only use #25 chain and 9 mm belt. That should give us a 4 way comparison.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 21-04-2009, 19:11
Brian C's Avatar
Brian C Brian C is offline
Doer of Whatever
AKA: Brian Cholerton
FRC #1468 (J-Birds)
Brian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant futureBrian C has a brilliant future
Very nice presentation and good information. Well done!
2017 Season; Game Announcer at
SBPLI Long Island Regional
Unread 21-04-2009, 19:17
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Interesting! and could you try V belts too?
We have looked at using toothed belts, and #25 chain, and have always used #35 because it's easy/available/inexpensive/forgiving. The extra weight is generally down low on the robot which makes it not very important, and the extra efficiency of belt seems to be negligible.
I guess as your team gets better at designing and building robots, the importance of these paramaters shifts.
Unread 21-04-2009, 19:26
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Testing v belts would be a waste of time. A team tried v-belts in the past and the results were very poor. V belts require high tension to function correctly thus reducing efficiency greatly over timing belt or chain.
Mentor 2415
Rookie Year: 1942
Think about it this way. We made one change between Purdue and Atlanta that made us 8% faster. That means in the time we could go 40 feet, we could now go about 43 - 44 feet. It doesnt sound like much, until you realize that is equal to a robot or a trailer.
Chris Fultz
Unread 21-04-2009, 19:32
AKA: Sean
So you did end up switching to timing belt on the real robot? I am planning testing timing belts this year either in a swerve drivetrain or in our standard 6wd. I am very curious to see how it holds up to the torque of a 2 speed transmission.
Mentor 2415
Unread 21-04-2009, 19:39
MrForbes's Avatar
AKA: Jim
We made a change between Arizona and Atlanta that made us go about 30% faster....we bought some sprockets from Small Parts Inc for under $10 each, and brought a short piece of #35 chain and a couple extra master links with us. I hate to think of what it would have taken to make this change if we had used a toothed belt drive.
If the robot is right at the edge of optimum performance (not the case this year), then the efficiency is important. Most years it does make some difference, but careful drive ratio selection might be more important. The wide availability of different tooth count #35 sprockets, and the ease of changing the chain length, seem to me to be a much bigger advantage, especially for teams like ours that don't have enough experience to get it right the first time.
My point is that there seem to be a lot of considerations that you left out, which may not be important to your team, but make a big difference to many other teams.
Still, it's great that you did the research, and showed us that there is advantage to be gained by careful experimentation. It would be neat to see more belts on robots next year. The experiments with smaller chain and belts will also be very helpful, and if more teams see the benefits, they will increase demand for the parts, and hopefully it will become even easier to make these changes.
Unread 21-04-2009, 19:40
MrForbes's Avatar
AKA: Jim
Did you get a chance to look at 1717's robot?
Unread 21-04-2009, 21:03
AKA: Sean
I definitely looked at there robot and I have many pictures saved of there robot. I have also talked with them about timing belt a little bit. IMO timing belt is far more effective than chain. The past 2 years, we have run #25 chain without incident and without any tensioning devices. While initially this would seem ok, the chain did still stretch. With kevlar reinforced belt, this problem would be eliminated. Additionally, changing belt for many designs would be as simple as changing wheels, which is something that many teams do throughout there regionals due to using conveyor tread. In our drivetrain this year it would have been almost as easy to replace belt as chain and certainly in the future it could be made even easier. Timing pulleys, especially polycarbonate ones, are much lighter than sprockets and cheaper as well. While I have had an enjoyable experience with #25 chain, I am also eager to test out timing belt for myself.
Mentor 2415
Unread 21-04-2009, 21:42
kapolavery's Avatar
kapolavery kapolavery is offline
All Your Base Are Belong to FIRST
AKA: Avery-John Domingo
FRC #2445 (RoboKAP)
kapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to beholdkapolavery is a splendid one to behold
so what does your team use?
we tend to just use bike chain for drivetrain
and we use pulley mechanisms with belt drive
"There's always next year..."
Unread 21-04-2009, 22:02
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
Due to the low friction between the wheels and the flooring this year, we used #25 chain.
Collin Fultz
paper: Cyber Blue 234 2009 Chairmans Essay Chris Fultz Extra Discussion 0 21-04-2009 09:04
paper: Belt vs. Chain Drive Evaluation - Team 234 Chris Fultz Extra Discussion 10 25-02-2009 14:09
paper: Cyber Blue 234 Business Plan 2008 Chris Fultz Extra Discussion 3 21-04-2008 12:53
paper: Cyber Blue 234 Chairman's Submission 2008 Chris Fultz Extra Discussion 1 20-04-2008 21:09
White Paper Discuss: Cyber Blue 234 Design Review Process 2004 CD47-Bot Extra Discussion 1 18-03-2004 22:51
