Go to Post You are done with designing something, not when there's nothing more to add, but when there's nothing left to remove. - EricH [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 21-04-2009, 23:48
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: 2009 Gigapan of Finals
Here is a quick stitching of one of the Gigapans that I shot from the back of Einstein during the competition finals.
(click on the image to link to the full Gigapan)
There is a lot of work still to be done with this image to pull out some of the blurred people and replace them with the clean sections of overlap areas, and balance out the colors. But this is a good first indication of what the final image will look like.
The image has small sections of significant blurring where people were moving rapidly while the sub-images were being acquired. Due to the uneven light coverage inside the Georgia Dome, I was shooting with a 1/8-second shutter speed (Canon G-10 at f4.5, full optical zoom, no digital zoom). This was slow enough to catch considerable movement in each frame. I shot the panorama four times, and have enough duplicate frames to clean up the blurred areas with a little bit of work.
-dave
Unread 22-04-2009, 00:13
TotalChaos's Avatar
TotalChaos TotalChaos is offline
AKA: Austin
FRC #2837 (Freebird Robotics)
TotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud ofTotalChaos has much to be proud of
Send a message via MSN to TotalChaos
Looks great Dave! I love it! Way better than mine, especially in terms of image consistency, and a great camera angle. I've already started snapping away taking snapshots of people I recognize that go on ChiefDelphi. (Hope you don't mind)
And Frank, I'm glad to see you got this up right away, I was just about to email you when I saw this thread. It looks great! And it makes me wish I would've taken full advantage of my camera's optical zoom in mine. Oh well, next time!
- Austin
The 39th Aero Squadron - Team 39! (Visit our website!)
Team Role: 3 Years as Driver - College Student/Mentor!
Freebird Robotics - On a 1 year hiatus! (Visit our website!)
Arizona 2009: Semifinalists! (69 and 498), Delphi "Driving Tomorrow's Technology" Award
Unread 22-04-2009, 02:24
Frank Neuperger Frank Neuperger is offline
FRC #0842
Frank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to beholdFrank Neuperger is a splendid one to behold
Austin,
Yes, for max zoomability in the in the pano, I generally go to the max optical on the camera. There are caveats however. For still subjects, zoom to max, but for crowds that are moving like this one, if you zoom too tight, you can end up with a ton of rework if you want to minimize motion artifacts of missing legs heads etc. The frequency of occurrence of these artifacts goes up as you zoom tighter simply because there are more frames (stitch boundaries) for a given size pano. Notice the right hand side of my image in the first posted pano as the subjects were closer. The stitching really chopped some of those people up because they were large in comparison to the frame and they were not sitting still.
Mechanically the Beta gigapan is so so. Ok for a light point and shoot. Because of the crush of trying to be competitive in ATL, I did not have the time to better integrate the camera with the Gigapan to ensure that the camera c of g was always on one side of the tilt axis for all angles of tilt. As such I got vertical smearing on some images. The shutter servo induced flex due to use of that small plastic spacer instead of the big aluminum spacer.
Also, I did not really fully test the delays associated with my auto focus to see if the gigapan was actuating the shutter before the autofocus settled. . To get great panos, you have to characterize all of the idiosyncrasies of your camera in the context of the Gigapan mechanism. .
I am going to add a bearing support on the STBD side of the Gigapan and remake the camera and shutter servo mounting plate out of 1/8 wall plate or extrusion to get it really rigid. This should also help the tilt axis "stiction" get a bit more deterministic.
After having to build that swerve steered drive for 09 , this will be a snap!!
Having a remote control (even if wired) to pause it for people to walk past would be another great addition. I hate having to touch it in case I push too hard an make the stepper slip. Not sure how to do this. Need to check if the code is open source and if there is some I/O left on the board.
Unread 01-05-2009, 13:42
FRC #0842
Great shot of Team 39
http://www.gigapan.org/viewGigapan.p...pshot_id=65908
Gigapan Panoramic Pictures - 2009 TotalChaos Championship Event 21 22-04-2009 13:34
finals video edomus Championship Event 0 20-04-2004 20:49
midwest finals shawny963 Thanks and/or Congrats 11 31-03-2003 20:43
Finals clarification Gui Cavalcanti Rules/Strategy 2 20-03-2002 17:38
Finals Qualifying Prothe General Forum 6 11-01-2002 21:24
