pic: 1712 version of JVN high reduction gearbox
Re: pic: 1712 version of JVN high reduction gearbox
That is one sweet trophy. If I won something like that I'd be trying to figure out how to run it around on the floor, and perhaps make it shift.
Well, not really a trophy. Petra just asked for the equipment to build it and bugged me until I gave the go ahead. When she finished it we created a mounting plate with a little placard to honor JVN's design, Mark Leon's "do the math, save the world" mantra, and Petra's effort. We will move forward using this to teach gear reduction calculations and gear theory to team members and to those who take our Engineering Design classes at LM.
I know it was probably a miss type, but I like the term "team embers". Are they the team members that keep the fire going ? ![]() |
Just out of curiosity (I'm not familiar with the FTC/VEX gears) what is the reduction per stage, and total reduction of that gear train? |
12 stages of 5:1 reduction, total ratio of 244,140,625:1
#7
JVN posted the applicable calculations with his original design here: http://www.chiefdelphi.com/forums/sh...ad.php?t=70627. And, as a finer point, these are VEX gears and I'm not sure what ratios you could produce using the current FTC kit gears. |
#8
I'm impressed by the gears, of course...
But the xkcd shirt is awesome. |
#9
Rich,
Any chance of making a parts list or design available for this? I would love to have our team build one. Thanks |
#10
We just followed from the original JVN picture and eyeballed it, selecting materials from what spare VEX part we had. JVN's version is much more compact than ours:
http://www.chiefdelphi.com/forums/sh...ad.php?t=70627 Here's an OK close up of ours: http://www.chiefdelphi.com/media/img...4275b627_l.jpg most browsers will enable you to magnify the image, or just save it and magnify with software Essentially, you just need to build a 12 stage reduction using: 4 VEX plates or chassis rails with appropriate width and length 12 12-tooth gears 12 60-tooth gears 1 big wheel on input side 1 small wheel on output side stand-offs shaft collars fasteners spacers shaft to size (only one shaft runs all the way through the gearbox - the one at the bottom) Last edited by Rich Kressly : 29-04-2009 at 14:06. |
#11
So, if my math is right, a cim motor on the input would take about a month to get 1 turn on the output.
#12
Thanks Rich, that is exactly what I needed to get working on one of our own.
| pic: VEX High Reduction Gearbox | JVN | Extra Discussion | 40 | 06-07-2009 16:58 |
| pic: 1712 version of JVN high reduction gearbox - 2 | Rich Kressly | Extra Discussion | 9 | 24-04-2009 01:14 |
| Gearbox/reduction for CIM,RS550,RS540 | uid60001 | Technical Discussion | 8 | 03-04-2009 22:01 |
| pic: Version 2 of the 2 CIM into 1 DeWalt gearbox | MAteo9944 | Extra Discussion | 3 | 21-01-2007 13:00 |
| Drill Motor Gearbox Reduction Ratios | archiver | 2000 | 3 | 23-06-2002 23:05 |
