Go to Post Is there a way to spotlight an entire thread? - ctt956 [more]
Unread 22-04-2009, 21:53
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Blinking RC and Runtime Errors
I'm work with the 2008 robot controller and currently have all of the lights blinking whenever I turn it on. I can get the program state light to turn solid orange, but that's as far as I've gotten with the lights. Also whenever I try to upload new code with the IFI Loader I get an error
Runtime Error '11':
Division by zero
I suspected it may have been a problem in the code I was uploading had a problem in it, but I've tryed several times and it's always been the 2007 defualt code hex file. The only other possible problem I see would be the difference in the 2007 code being uploaded to the 2008 controller, but I asked that question in an earlier thread and was told I should have no problem as a result of the year difference. Can someone tell me what I might be doing wrong.
Unread 22-04-2009, 22:02
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Re: Blinking RC and Runtime Errors
Try reloading the master code. To do so, IIRC, just choose the master code file (I think its name starts with "FRC") in IFI Loader and download while the RC is tethered to the OI.
Go directly to queue. Do not pass pit.
Unread 22-04-2009, 22:23
jamie_1930's Avatar
Team Role: Student
I gave it a try but still recieved the same run time error
Unread 22-04-2009, 23:10
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
Runtime Error '11':
Division by zero
Looks like MORT and 229 have been playing pranks again.
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 23-04-2009, 09:53
heydowns's Avatar
heydowns heydowns is offline
AKA: Jeff Downs
FRC #1511 (Rolling Thunder)
heydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond reputeheydowns has a reputation beyond repute
Originally Posted by jamie_1930 View Post
Runtime Error '11':
Division by zero
This sounds like IFI Loader's installation is messed up on your PC. Can you successfully load any IFI control system with this PC? Can you try another PC with a fresh IFI Loader installation?
Loading '08 controller with '07 code should be fine, and starting with the pre-built default code is a good idea if you are having problems.
blinking program light tseres Control System 3 08-04-2007 17:45
Blinking Red Light teh_pwnerer795 Programming 8 21-12-2006 23:13
Code Errors With "Bells and Whistles" Ryan O Programming 2 31-01-2006 19:29
VEX Battery Pack Runtime? TennBikeBerk FIRST Tech Challenge 4 04-08-2005 18:12
Blinking Program light on RC jgannon Programming 2 16-02-2005 22:45
