Go to Post Let’s not scare the newbies away, let’s welcome them and help them. - Arefin Bari [more]
Unread 23-04-2009, 08:11
colo colo is offline
colo is an unknown quantity at this point
Re: a problem with Microcontroller
First of all , I used the circuit shown in the link :
http://www.dprg.org/tutorials/1998-04a/hb6.png
when my PIC fails ( which mean programmed but not execute ) , I turned to H-Bridge ( SN754410NE ) , and the same problem becomes
I made a program that make all pins to output , but nothing happens
It programmed with no errors at all using winpic and IC-prog , but when connect it to run the program it did not work at all
I did not think it is dc motor driver because I used transistors and H-bridge
but what is really happend , I still have no idea !
Victor turning on and off under load, with non-IFI microcontroller pludodog Electrical 17 28-09-2009 08:07
[FTC]: Problem with Code or Problem with Bluetooth? VeedotJaydot FIRST Tech Challenge 3 27-01-2009 18:22
Problem with Lofting cooker52 Inventor 14 04-11-2007 15:00
Problem with communicating with STAMP through serial port Skabana159 Technical Discussion 2 06-02-2003 21:10
Problem with OI / RC Jay Lundy Technical Discussion 2 29-03-2002 23:07
