Go to Post [You know you've overdoes on FIRST when...] You're willing to take an 8 AM for the team. - ttldomination [more]
Unread 24-04-2009, 11:02
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Re: Questions about crab/swerve drive.
Originally Posted by BenX02 View Post
Hey, our team is wanting to have crab drive next year, so I have been coming up with designs. I have a few questions.
4) I know you need lots of sensors, but what kind and where might I get them?
Thanks in advance.
You need to use pots on the steering, or possibly encoders (startup position can be tricky). You should also consider encoders on each drive wheel. It has been said many times on these forums and is worth repeating... Building the crab modules is just one part of the system, controlling it is often toughest part.
Crab Drive Questions craigboez Technical Discussion 18 13-01-2009 21:35
Crab / Swerve drive joystick control scheme Tom Line Programming 12 16-04-2007 18:47
Simple Swerve/Crab Rob2713g Technical Discussion 4 20-03-2007 19:00
Swerve/Crab Rob2713g Technical Discussion 5 12-11-2006 22:05
Swerve/crab drive and tank turning activemx Technical Discussion 9 23-02-2004 18:26
