Go to Post One of my early mentors gave me wise words -- when designing a system to compile & analyze information, your first design choice should always include consideration of a stack of 3x5 file cards. - Jaxom [more]
Unread 24-04-2009, 23:55
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Re: Win32 Hooks
I'm running Vista. Anyways, WH_KEYBOARD_LL apparently catches messages when "a new keyboard input event is about to be posted into a thread input queue" and WH_KEYBOARD catches messages "whenever an application calls the GetMessage or PeekMessage function and there is a keyboard message (WM_KEYUP or WM_KEYDOWN) to be processed". For my purposes, I thought WH_KEYBOARD would be fine. And according to the MSDN explanation of SetWindowsHookEx(), WH_KEYBOARD should be able to run globally.
EDIT: Using WH_KEYBOARD_LL, the hook works globally. However I cannot do what I wanted to (which is change the keystroke en-route to programs). WH_KEYBOARD_LL passes a pointer to a struct containing they key data (such as key code, etc.) as it's lParam, but i have found that changing the data in the struct does not affect the output (even If I change the keycode the key remains the same). Can't I change the data in the message using the hook?
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
win32 dialog help Chris Bright Programming 10 30-12-2004 00:17
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Win32 API Port Connection Help Raven_Writer Programming 3 17-01-2003 14:23
Win32 Dialog Help Raven_Writer Programming 2 12-01-2003 09:37
