Go to Post I thanked the tradesmen on our team the same way i do ever year with a handshake and a "thanks for helping us guys", - Mike Schroeder [more]
Unread 27-04-2009, 05:27
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: Win32 Hooks
Originally Posted by slavik262 View Post
WH_KEYBOARD_LL passes a pointer to a struct containing they key data (such as key code, etc.) as it's lParam, but i have found that changing the data in the struct does not affect the output (even If I change the keycode the key remains the same). Can't I change the data in the message using the hook?
You should be able to do this by modifying the vkCode in the lParam struct before calling CallNextHookEx. This function passes on the key on to the next handler in the hook chain, so passing a modified lParam will mean that all handlers that were registered before your (including the default windows handler) will see the modified value. At least that's how it works in theory.
Let me know if that works.
--Ryan
P.S. I'm not sure why WH_KEYBOARD_LL works and WH_KEYBOARD doesn't. I think I remember running into the same issue with mine. Maybe posting to the MSDN forums would shed a bit more light on the subject.
FRC 766, 2015-, Mentor
Special grappling hooks for throwers? ShadowNinja General Forum 3 04-01-2009 17:48
win32 dialog help Chris Bright Programming 10 30-12-2004 00:17
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Win32 API Port Connection Help Raven_Writer Programming 3 17-01-2003 14:23
Win32 Dialog Help Raven_Writer Programming 2 12-01-2003 09:37
