Go to Post Proof: Remove the motor from it's mechanical house of bondage and it will operate just fine - Mike Betts [more]
Unread 26-04-2009, 23:26
Founder Founder is offline
AKA: Riley Found
Founder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud ofFounder has much to be proud of
Re: pic: FRC 2753, Team Overdrive 2009 Robot
Did you guys ever have problems with the hopper having a flat bottom, instead of having a sloped bottom to the front where the roller is?
Unread 26-04-2009, 23:31
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
well the base of the hopper comes up to a slant with the use of what i believe is a window motor. you may have seen this on 103's modification to a power dumper which was a concept they took from 2753.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 26-04-2009, 23:34
R.C.'s Avatar
R.C. R.C. is online now
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Team 11 was one teams to lift their hopper up and dump (using a pneumatic piston). 2753 does the same thing but has rollers in the front aka making it a power dumper. But as pointed out earlier, overdrive uses a window motor.
R.C.
MadTown Robotics Team 1323
Unread 27-04-2009, 10:00
craigcd's Avatar
craigcd craigcd is offline
FRC #2221 (RoboDawgs)
craigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant futurecraigcd has a brilliant future
I was the field supervisor for the Archimedes Division. The only problem I had with your robot is that every time that you competed I had to have two field reset people swifter the playing field to remove the worn conveyor belt material. Congratulations to your team on a wonderful championship. I expect to see great things from your team in the coming years. See you next year at the championship.
Unread 27-04-2009, 10:24
Lowfategg's Avatar
Lowfategg Lowfategg is offline
Building cars now....
AKA: Tyler Moser
FRC #2016 (Mighty Monkey Wrenches)
Lowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond reputeLowfategg has a reputation beyond repute
Send a message via AIM to Lowfategg
Originally Posted by craigcd View Post
I was the field supervisor for the Archimedes Division. The only problem I had with your robot is that every time the you competed I had to have two field reset people swifter the playing field to remove the worn conveyor belt material. Congratulations to your team on a wonderful championship. I expect to see great things from your team in the coming years. See you next year at the championship.
Haha, yes we did notice that.
We replaced the belt on Thursday with a new one and for some reason the new one shredder like paper. The older ones held up much better, so I am not sure what happened.
Anyway, sorry about that!
Mechanical Engineering Student at WPI.
Mightly Monkey Wrenches FRC #2016 - 2010-12 (Mentor)
Past: FTC #74, FVC #3179, FVC #73, FRC #303, FRC #2753
Unread 27-04-2009, 20:17
Coach Tom Coach Tom is offline
FRC #2753
Coach Tom is a jewel in the roughCoach Tom is a jewel in the roughCoach Tom is a jewel in the roughCoach Tom is a jewel in the rough
If I remember correctly - Tyler - we changed suppliers of the "shelf-liner" material: Contact versus Kittrich. Also, we used Gel Contact Cement originally -- made by DAP. Our new belt used 4 minute spray contact cement from 3M. The sheddling of the belt did not happen in either NJ or NYC.
Lesson learned: do not change suppliers without adequate testing.
pic: Team Overdrive's (#2753) 09 frame teaser Lowfategg Extra Discussion 23 28-01-2009 01:49
FRC 2009 Robot Simulator? RedOctober45 Programming 4 27-01-2009 21:45
Team Overdrive Joining FRC Lowfategg General Forum 21 03-08-2008 22:22
pic: Team 2070's Overdrive Robot, Rambo! losedemnoodles Robot Showcase 8 20-02-2008 00:20
pic: finished 2008 overdrive team 1708 robot D_Price Robot Showcase 3 19-02-2008 13:41
