Go to Post I find it quite amazing that this thread has been continuously active for more than two years. - Stephanie [more]
Unread 25-10-2001, 07:36
Guys,
No one should ever run untethered in the pits. The possibility for you to interfere with the the main event is as real as them interferring with you. Imagine a robot in the pits running without control, this is a safety issue as well as a competition issue.
There are not an infinite number of frequencies in use by the radio modems. This is a common misconception. Please see the docs on the Innovation First products and how they are configured during competitions. More than two modems on the same frequency could conceivably handshake to the wrong controllers.
In all cases of strange behavior, check the LED's on the controller, they tell a lot about what is happening. The Innovation First engineers have really built a lot of nice things into that box. ABove all, remember that the controller will reset below 8 volts at the supply terminal, this will take out the controller for a few seconds to reboot, modems to handshake and begin running your software. Stalled motors combined with low charge on the battery will make this happen.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
