Go to Post I survived the Great CD Spamming of 2006. - Michelle Celio [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 29-04-2009, 14:25
Gerry_TECH Gerry_TECH is offline
Gerry_TECH is an unknown quantity at this point
Arrow Scorbot Robotics cell with table top Conveyor
Hi Folks,
I just wanted to show you all my Scorbot setup with some custom conveyor work that I put together using Industrial Flex-link conveyor chain. I've been using several models of the Scorbot series robots for more than five years now, talk about fun.
I finally got my controller-A interfaced properly and running very smoothly with ATS ACL software.
The Scorbase software for the ER-III controller is ok too, but I prefer using the controller-A ACL software, so on that note the ER-III connected to this controller is essentially a mod to an ER-V robot.
My plan is to mod a ER-4PC that I have to an ER-V Plus and run it with the controller-A unit as well.
I'm also doing some work with CRS 265 robots, fun fun!
Scorbots are Awesome!!
-Gerry
Here's a few shoots from the building phase.
The yet to be moded ER-4PC on the Flex-Link Conveyor table
This is my Controller-A unit running ACL software
My ER-III robot getting ready to be interfaced to the ACL controller
Some New Flex-Link chain I just got to build a new conveyor table with the Drive unit under the table for Continuous Flow, as compared to the previous model shown above.
Unread 29-04-2009, 14:31
Re: Scorbot Robotics cell with table top Conveyor
The Drive Unit is on top of the chain which prevents continuous flow. I just connect some sensors in front of the drive wheel to stop the conveyor.
In any case, it's Pretty Sweet!
-Gerry
Unread 29-04-2009, 16:23
Here is a yahoo group Devoted to Scorbots with lots of resources.
It has lots of documentation and computer related interfacing and programming, many experience users have joined.
Enjoy.
http://tech.groups.yahoo.com/group/ScorbotUserGroup/
-Gerry
Unread 29-04-2009, 18:39
Chief Pride's Avatar
Chief Pride Chief Pride is offline
<3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Just curious... What will you be doing with it?
Unread 30-04-2009, 01:43
Arrow Re: Scorbot Robotics cell with table top Conveyor
At this point it's strictly a hobby and mainly just to learn .....it's crazy fun.
My end goal is to research and experiment with Video Image analysis using MatLab software. Interfacing a CCD video camera that can capture objects being moved after the program has begun. Feedback data is sent to the controller from MatLab and the robot re-calibrates itself to compensate while running it's program.
A friend of mine did some work on this while in University. It was so amazing, trying to fool the robot by moving the block and it was like you were trying to steel a piece of candy from a child or something. Regardless of where you move an object for the robot to grab, the robot followed and still picked up the object. Pretty old school stuff actually, they first did this back in the early 80's...... but it's lots of fun regardless.
So, we'll see how it goes.
-Gerry
Unread 23-11-2009, 20:24
A few other Pics of some Scorbots I used in College. Pretty sweet.
And here is an ER-XI Sorbot. This one uses the Controller-B unlike the ER-VII that uses the Controller-A.
Don't forget to check out my Scorbot YouTube Channel !!
http://www.youtube.com/user/NLEproGUY
-Gerry
Unread 16-03-2010, 08:38
rock333 rock333 is offline
None #0423
rock333 is an unknown quantity at this point
great machines...hey...this is amazing i am new here and i found this site very interesting and informative ,, you are a professional blogger i think thank you for the post buddy and keep on posting nice stuff like this
__________________________________________________ _______
m comptia certification student
Unread 18-03-2010, 22:45
Thanks for the appreciative reply!
It's been a while since I made a post here.
I've made some serious advancements in my Robotics Lab since then.
I've added a Pneumatics control board to my Lab which allows me to control compressed air into various Pneumatic Pistons and also some Suction cup end effectors for my Robotic Arms.
Check it out! It's pretty sweet.
This above is the Robotics area during the addition phase of the Pneumatics Control board. A BIG mess of junk all over the place. You can see the control board on the Wall to the left.
Here above is the Pneumatics Control Board. Which entails a Pressure Regulator and an Air Dryer to remove moisture from the input lines. Also connected, is a Digital Pressure switch for interfacing to the Robot Control Modules. I then have three separate Solenoid Manifold units, for channeling the Air Pressure through various tubes attached. These are essentially decks of electro-magnets that open air flow valves when you send a logic High voltage to the units input connections.
Each unit here has eight channels to use. So this gives me a total of 24 Channels to channel the Pressurized air into different pistons or other Pneumatic devices. You can also see the Vacuum Generator on the Right Bottom side of the Control Board. This device will take a compressed air input and create a vacuum for connecting suction cup end effectors.
Pretty Awesome!!
Unread 28-03-2010, 14:48
If you look closely you can see the old school Nintendo PowerGlove.
Unread 15-04-2010, 04:18
http://xa.yimg.com/kq/groups/1942673...ot_Lab_007.jpg
Unread 15-04-2010, 04:22
http://xa.yimg.com/kq/groups/1942673...ot_Lab_006.jpg
Unread 15-04-2010, 04:24
Unread 15-04-2010, 08:23
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Just so you know the er4pc will work as a er5+ without any changes.
Unread 15-04-2010, 09:34
ISGOI Howie ISGOI Howie is offline
FRC #2996
ISGOI Howie is an unknown quantity at this point
our school has a computer integrated manufacturing class(best in the school lol) and we get to play with 2 er-4u and some PL1000 CNC mills(still trying to get handshaking to work).... but we don’t have nears as fancy a setup as this
VBA - How to put data in cell with macro? indieFan Chit-Chat 1 28-12-2008 21:37
pic: Green Machine Competition - 10 Cell Fuel Cell Stack Conor Ryan Extra Discussion 18 04-01-2007 08:09
"Familiar Looking" Table-Top Robotics Project Vince Robotics Education and Curriculum 6 21-08-2005 17:28
Scorbot ER 3 Software Leav Kit & Additional Hardware 3 22-12-2004 15:42
using SCORBOT for disabled people kandyuee Robotics Education and Curriculum 2 16-04-2004 07:31
