Go to Post MR. KAMEN! TEAR DOWN THIS WALL! - Briansmithtown [more]
Unread 27-04-2009, 19:35
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
Re: Portable Windriver
i retried everything you just said, but i still get the same error, is there any other way to do it besides using apache?
Unread 28-04-2009, 15:33
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
I think you can do something like svn://x.y.z.q/repositories/path/not/ending/in/a/slash
never tried that.
are you sure that in (apache)/conf/httpd.conf you have the line LoadModule dav_module modules/mod_dav.so uncommented (without a semicolon at the beginning)?
Watchdog.Kill();
Unread 28-04-2009, 16:27
AKA: Josh
never tried that.
I tried it without the # sign at first, but then i get errors, so i tried it with the # sign and just came up with the DAV error
Unread 28-04-2009, 21:11
byteit101's Avatar
OOps! # is the comment, not ; I was thinking php.ini
you want it without the # sign to uncomment it (what is the error?)
Watchdog.Kill();
Unread 30-04-2009, 13:19
AKA: Josh
This is what i inserted in the httpd file
LoadModule dav_svn_module modules/mod_dav_svn.so
LoadModule authz_svn_module modules/mod_authz_svn.so
<Location /svn/>
DAV svn
SVNListParentPath on
SVNParentPath C:/Repositories /* This is where my default folder is */
</Location>
the error that get is
Unread 30-04-2009, 15:17
byteit101's Avatar
recopy mod_dav_svn.so to the modules dir from the svn dir. if that does not work, reinstall subversion (existing repositories will be kept)
EDIT: and of course, re-copy it
Watchdog.Kill();
Unread 30-04-2009, 17:55
AKA: Josh
I tried what you said and made sure i install subversion with apache 2.2.x I also double checked that both .so files were in both locations. This is the error that I am getting now.
Unread 01-05-2009, 16:59
byteit101's Avatar
could you post the last 30 or so lines from (apache)/logs/error.log?
Watchdog.Kill();
Unread 04-05-2009, 20:56
AKA: Josh
Starting the Apache2.2 service
The Apache2.2 service is running.
] Apache/2.2.11 (Win32) configured -- resuming normal operations
[Fri Apr 24 23:03:57 2009] [notice] Server built: Dec 10 2008 00:10:06
[Fri Apr 24 23:03:57 2009] [notice] Parent: Created child process 4636
[Fri Apr 24 23:03:58 2009] [notice] Child 4636: Child process is running
[Fri Apr 24 23:03:58 2009] [notice] Child 4636: Acquired the start mutex.
[Fri Apr 24 23:03:58 2009] [notice] Child 4636: Starting 64 worker threads.
[Fri Apr 24 23:03:58 2009] [notice] Child 4636: Starting thread to listen on port 80.
httpd.exe: Could not reliably determine the server's fully qualified domain name, using 127.0.0.1 for ServerName
[Mon Apr 27 17:58:11 2009] [warn] pid file C:/Program Files/Apache Software Foundation/Apache2.2/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run?
[Mon Apr 27 17:58:11 2009] [notice] Apache/2.2.11 (Win32) configured -- resuming normal operations
[Mon Apr 27 17:58:11 2009] [notice] Server built: Dec 10 2008 00:10:06
[Mon Apr 27 17:58:11 2009] [notice] Parent: Created child process 2384
[Mon Apr 27 17:58:11 2009] [notice] Child 2384: Child process is running
[Mon Apr 27 17:58:11 2009] [notice] Child 2384: Acquired the start mutex.
[Mon Apr 27 17:58:11 2009] [notice] Child 2384: Starting 64 worker threads.
[Mon Apr 27 17:58:11 2009] [notice] Child 2384: Starting thread to listen on port 80.
[Thu Apr 30 14:51:13 2009] [notice] Parent: Received shutdown signal -- Shutting down the server.
[Thu Apr 30 14:51:14 2009] [notice] Child 2384: Exit event signaled. Child process is ending.
[Thu Apr 30 14:51:15 2009] [notice] Child 2384: Released the start mutex
[Thu Apr 30 14:51:16 2009] [notice] Child 2384: All worker threads have exited.
[Thu Apr 30 14:51:16 2009] [notice] Child 2384: Child process is exiting
[Thu Apr 30 14:51:17 2009] [notice] Parent: Child process exited successfully.
Unread 05-05-2009, 22:03
byteit101's Avatar
hmm,
your httpd.conf looks like this (at the end)?
#make sure its /svn not /svn/
<Location /svn>
DAV svn
#same here, also remove the /**/ comment
</Location>
restart the server, and tell me if it works now
Watchdog.Kill();
Unread 06-05-2009, 01:20
AKA: Josh
thanks a lot, that finally worked, so now i can access the repo from a remote location by using the server computer address correct?
Unread 06-05-2009, 19:55
byteit101's Avatar
yes, on the network, (if your ip is 192.168.1.103 (use ipconfig))
file>new project: SVN+new project from svn: http://192.168.1.103/svn OK
Over the internet, you need to configure the router to send port 80 traffic to the computer that has the repos on it, then google what is my ip, and click teh first result, and (pretending it is 72.123.852.95) you would enter in the new repos location box http://72.123.852.95/svn
I would look at the help on it to (in the help menu, and google svn book) learn about commiting, updating and stuff
Watchdog.Kill();
pic: 1726 - portable OI TheOtherGuy Extra Discussion 1 07-03-2008 18:53
paper: Portable Inspiration Phil Ross Extra Discussion 2 02-11-2007 11:26
Portable Software Pavan Dave General Forum 17 23-07-2007 09:07
Portable Racks aksimhal General Forum 8 02-05-2007 12:46
Portable IDE Nitinol Programming 14 04-02-2007 03:23
