Go to Post I've got it! INFLATABLE clown fish!!!! - dlavery [more]
Unread 30-04-2009, 14:14
Joining the 900 Meme Team
FRC #0079
Re: FIRST Event Data in XML format
Update to this, the corrections I made for Dallas and Connecticut did not work, I will be trying to fix those later tonight.
As a consolation prize I tossed together a quick (read simple and not pretty) page you can grab xml data from using scripts though I would prefer you run the script on your own machines. If you want a one off piece of data feel free to use it.
http://schreiaj.ath.cx/share/FRC_Parsers/ranking.php
The page takes a couple of arguments, Event_Code which is the event code used by FIRST, these can be found on frclinks.com. It also takes HTML_Display which is either true or false. A true value will encode the page such that the tags for the xml show up in the browser, otherwise they will not. HTML_Display is optional but without an Event_Code the page will not load anything.
An example is
http://schreiaj.ath.cx/share/FRC_Par...Event_Code=GLR
It will load the Lansing District event to display in the browser. Any questions feel free to ask.
I will be making the updated script available as soon as possible. Sorry about that.
EDIT: The Championship divisions rankings do work, FRClinks has the wrong code for them, it is the full name of the division. ie, Newton is Newton.
XML Interchange format Nibbles Scouting 25 03-10-2008 02:09
How to write image data to binary PGM file format(P5)? tommy_chai Programming 0 08-10-2007 08:22
Scouting Data Interchange Format proegssilb Scouting 7 06-06-2007 19:29
White Paper Discuss: Karthik's Championship Event Data CD47-Bot Extra Discussion 20 13-04-2004 08:17
XML of the FIRST Q & A system Jack Website Design/Showcase 11 16-01-2004 23:24
