Go to Post FRC: more like the real world than we could ever want. - efoote868 [more]
Unread 30-04-2009, 13:20
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
Power Driver Station with Serial
At competition everyone's driver station was powered just by the serial. Anyone know how they hooked that up?
Unread 30-04-2009, 13:38
TJ Cawley's Avatar
TJ Cawley TJ Cawley is offline
THE Freshman
FRC #1108 (Panther Robotics)
Team Role: Driver
TJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the roughTJ Cawley is a jewel in the rough
Re: Power Driver Station with Serial
its all in the software. they have the driver systems and at competitions there is some built in recognising software tht will determine if the connection is by a certain pit or by the field admin.'s. well, thts my guess anyway.
Unread 30-04-2009, 13:46
What serial?
The DS power at a competition field was provided through the competition connector, That's where the dongle with the enable switch goes when not at an official field.
Unread 30-04-2009, 14:18
Originally Posted by Alan Anderson View Post
What serial?
Alan is correct. That port isn't an actual serial port, it is some sort of hybrid creatureish-monster thing.
Unread 30-04-2009, 14:20
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
What serial?
The competition port was a D-sub connector though, wasn't it? I'm not trying to be sarcastic, I'm really trying to find out.
But anyways, I can almost remember seeing some FIRST documentation on it. I'll try to dig it up and post it for you.
Edit: Closest thing I could find was this. I really wouldn't recommend trying to make your own connector. The DS is already pretty janky as is.
Edit 2: I fixed the link.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 30-04-2009, 14:52
The only official documentation I know of is in section 3 of the FRC Control System manual.
Competition Port – Connects to the Field Management System through a DE9 connector to provide power and enable/disable during competition. Pinouts for this connector are in section
The text in the manual stops without identifying the section. Section 3.1.7 is labeled "Competition Port Pinouts" but has very little actual pinout information.
The competition port is used to enable / disable the robot. A “dongle” is provided in the Kit of Parts for teams to use for this purpose when not in a competition. If teams need to make a replacement dongle or need additional spare dongles, a team-constructed dongle can be fashioned by connecting pins 8 and 9 of the competition port to a switch. NOTE: it is essential that the other pins of the connector be left unconnected, as some of the other pins contain power and/or ground – accidentally shorting other pins of this connector can permanently damage the Driver Station.
If you really want to power your Driver Station through the competition port connector, you can very easily check for continuity between the power input jack and specific pins on the port.
Unread 30-04-2009, 19:53
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
I'm not sure that this would solve your particular need. But since you weren't allowed to use wireless in the pits...
What we did to provide power to our DS while working on the robot, was to use
the power meant for the wireless gaming adapter. It has the same power requirement as the DS. So all the power came from the 12volt battery on the robot.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Power for Driver Station mutantblond Technical Discussion 26 11-03-2009 01:20
Driver Station Power at the competition. Robo640 FRC Control System 3 13-02-2009 16:59
Problems with driver station gyaniv FRC Control System 2 13-02-2009 01:21
Reading battery power on Driver station. Digmaster Electrical 8 31-01-2009 20:09
Timing with the Driver Station Zorkinian Programming 6 10-01-2009 09:42
