Go to Post IRI: where egos go to die...uhm..I mean fly! - Koko Ed [more]
Unread 03-05-2009, 14:33
timmmoore timmmoore is offline
FRC #1899
timmmoore is on a distinguished road
Re: anyone else use the I2C bus?
Steve, I have tried 1 and 2 byte reads on CMPS03 without problem with SRF08 running at the same time.
I also found a way to cause the I2C bus to hang with both devices being accessed at the same time.
Difference
hang: 2 parallel while loops, 1 accessing CMPS03, 1 accessing SRF08
no hang: 1 while loop, accessing SRF08 then CMPS using a sequence
If you remove 1 or the other device physically from the bus but leave the code running both 'work'. But with both connected it may hang - it normally works for a while then hangs the while loop - I would expect this unless the I2C FPGA code has locking behavor for multiple accesses, you would end up with multiple conflicting bus accesses.
So you probably want to put all I2C accesses in 1 thread, store the results in local/global variables and access the variables when needed.
Does anyone else use the Dvorak layout? Michael Hill Chit-Chat 12 25-03-2006 23:47
Ultrasonic Rangefinder Operating On I2C Bus CapnBFG Electrical 10 04-06-2005 01:31
Does anyone else NOT use a long arm to place a tetra on top of the Goal? mad_cloversc General Forum 29 08-03-2005 00:44
Anyone else pumped for Bash @ the Beach? rocknthehawk Off-Season Events 24 08-10-2004 16:12
Anyone else irresponsibly overlooked by the judges? archiver 2001 12 24-06-2002 03:31
