Re: Have an IFI control system you don't need?
Any RC from 2004 or before most likely will need some serious work to make work with EasyC (or C, for that matter).
Allow me to present a history of IFI robot controllers and the languages they used, assuming that my memory is correct: 2003: PBASIC 2004: C 2005: C 2006: C, more memory than 2005. Not sure about EasyC capability. 2007: C, EasyC 2008: C, EasyC You want a 2007/2008 model, and 2006 might be acceptable. I'm pretty sure that anything before 2005 won't work right with EasyC. However: You are asking for the OI. As I recall, programming that isn't an issue. I'm not even sure it takes programming! So anything from 2005 or later *should* work. Pre-2005, probably not. Also note that IFI sells the control system components still. They are kind of pricey... over $700 for just an OI and 2 modems... Last edited by EricH : 03-05-2009 at 23:46. Reason: Memory incorrect on 2004 |
| Quotes that you don't have room for... | Cody Carey | Chit-Chat | 45 | 10-06-2007 03:09 |
| IFI Control System (OI/RC) - The Future??? | ChuckDickerson | Control System | 56 | 03-06-2006 20:25 |
| pic: What do you do when you don't have enough money to buy 6 IFI wheels? | Arefin Bari | Extra Discussion | 1 | 14-02-2006 01:14 |
| Important IFI Control System Update | Kevin Watson | Control System | 5 | 25-02-2004 23:31 |
| You have anything you don't like about the new forums? | Ken Leung | CD Forum Support | 16 | 16-06-2001 15:37 |
