Go to Post I'll admit that the events at Epcot were pretty nice, but they too had their problems. . . You were at the mercy of the weather, and Disney hasn't figured out how to control that yet. - Kevin Sevcik [more]
Unread 05-05-2009, 07:47
Re: Review of a small motor controller schematic.
Austin,
First thing to add is the protection diodes across the motor leads as shown in the TI specsheet. These are normally a part of the power FETs in our current controllers so with the L293D they have to be added externally. Insure that the diodes are placed on the board such that large motor currents do not inject noise into the power supplies. Normally this is done with separate return traces just for the diodes and motors tied back to power input. Also keep in mind the maximum current specs of 1 amp when you choose your motors. Also check the requirements for the bypass caps on the LM1117. High output capacitance near the chip might be detrimental. The spec sheet shows a 22mmf. Something larger may cause current foldback when starting.
Let us know how it works.
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
Small motor used as sensor JoelP Rules/Strategy 19 07-02-2006 17:25
What with the small motor? Robb Gerber General Forum 10 10-01-2002 14:10
