Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 05-05-2009, 12:33
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
Post-Competition Wireless
we were trying to get our robot to run wirelessly with the router that had been given to us in the kit of parts for a demonstration, however we were only able to get the robot to run while tethered
Unread 05-05-2009, 12:47
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
Re: Post-Competition Wireless
can you please provide more information? have you checked to see that none of the settings have been changed. Are you able to ping the ip address? Was it working fine before the matches?
Unread 05-05-2009, 12:49
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
I'm not sure if this will help, but try doing a hard reset on your gaming bridge (the black one on your robot) and reconfiguring it. Maybe the WPA code was still set from your last regional.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
yarb65 yarb65 is offline
Coach
AKA: T Bray
FRC #3189 (Circuit Breakers)
yarb65 has a spectacular aura aboutyarb65 has a spectacular aura about
Did you reset the WPA?
2013 Sacramento Regional Winner (3189,701,2489))
2012 Israel Regional Winner (1662,1690,1937)
2008 Sacramento Regional Winner (1662,115,2122)
2006 Sacramento Regional Winner (1662,852,1726)
Unread 05-05-2009, 13:07
AKA: Josh
i know that at our regional, some teams actually did get the wrong WPA key, just try reconfiguring the wrt610 also.
Unread 05-05-2009, 13:35
dwodrich dwodrich is offline
FRC #1706
dwodrich has a spectacular aura aboutdwodrich has a spectacular aura aboutdwodrich has a spectacular aura about
I had the same problem after returning from Atlanta. Even after resetting the bridge, I was still unable to even sign on to it (wired or wireless). Finally I took the device home and plugged it into a wired only router and suddenly had no problems at all.
I guess the inability for the wireless to connect somehow stopped the wired connection from working as well.
Hope this helps,
Darrell
Unread 05-05-2009, 14:12
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Unplug the lan cord that runs to your crio from the gaming adapter (unplug it at the gaming adapter)
1. Reset the gaming adapter to factory. (There is a small button that can be depressed with a paperclip to reset it. You may need to hold this button down.)
2. Run a wire directly TO the gaming adapter from your computer port.
3. Go into your computer's network properties, go the network adapter you are using, then highlight the TCP/IP settings and click properties again. Set the settings to
IP address: 192.168.1.(anything except 250)
Subnet Mask: 255.255.255.0
4. Log in to the gaming adapter and follow the instructions found on the first website under control systems, chapter 5, Section 5.6.1. You want look at the gaming adapter configuration specifically - start at step #5.
Link to control system manual:
http://www.usfirst.org/uploadedFiles...ation-0-5c.pdf
This should enable your gaming adapter to work again with system. This is assuming your Router setup is STOCK, without any WPA added. After you've finished with the directions in the manual (starting from step 5), unplug you network cord from the gaming adapter and plug your gaming adapter back into your CRIO. Reboot everything.
Please note, after the step where you reset the gaming adapter's IP and subnet, you will NOT be able to connect to it from the IP address and subnet I listed above - so when you save it in the gaming adapter and it reboots, your web browser will no longer be able to pull up the page (unless you change your subnet and IP back to the programming settings of 10.team.number.6 and 255.0.0.0).
Don't forget to set your programming computer back to the correct IP address to program.
Unread 05-05-2009, 14:19
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Hope this helps,
Darrell
Actually what likely happened is that by performing a hard reset of your Wireless Game Adapter you restored it to the default address which is in the 192.168.1.xxx range. Your team's Wireless Router was still set up for the 10.xx.xx.xx range and would give your computer an address in this range as well. This would prevent you from accessing the Wireless Game Adapter.
Unread 05-05-2009, 15:35
FRC #1706
It did reset and I was trying to use the 192.168.1.250 default address. I just couldn't get it to talk to me till the wireless router was out of the picture.
Unread 05-05-2009, 15:42
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Right, your wireless router was setup using the 10.xx.yy.zz range where xx and yy are your team number. When you took the device home and connected it to your router it worked because most people leave their home networks setup with the default 192.168.1.xx addressing scheme.
Connecting it directly to your computer would have worked just fine as well, as listed in the procedure posted above by Tom Line.
Unread 05-05-2009, 15:57
techplex's Avatar
techplex techplex is offline
Blake B
AKA: Blake
FRC #4909 (The Bionics)
techplex is just really nicetechplex is just really nicetechplex is just really nicetechplex is just really nice
We had a similar issue....
It could be one of any number of things:
*At the competition they install a wep key on your bridge(on robot)
-- I would reset all of your devices, (hold reset button and restart)
-- you may have issues with ip addresses, (set computers to auto config)
-- then reconfigure according to 5.6.1 Configuration of Wireless Bridge for Robot (WGA600N)
*During a demonstration while our robot was tethered, it stopped working
-- bad Ethernet port on drivers station
contact me if you need more help
blake (at) team2648.com
Blake
Electrical, Programming and Design
Creator FRC Q&A 2017
Mass FRC Team 4909: The Bionics
Maine FRC Team 5122: The RobOTies (2014-2015)
Maine FRC Team 2648: Infinite Loop (2008-2011)
Unread 06-05-2009, 00:24
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
That PDF would have been really useful to have downloaded before yesterday. We had a demo in the basement of the TX capitol, so there was little wireless reception, and all of the capitol wireless networks were hidden and encrypted, so no internet. But I managed to get both of our 2009 robots working again after about an hour and a half of hacking.
I used the "Wi-Fi Protected Setup" tool on the router. Basically, I setup all the correct settings on the router that I could remember (all encryption disabled, team number SSID's, IP pool range) and then followed the instructions for the Wi-Fi Protected Setup. I couldn't get anything to work until I had all the right things configured in the right way at the right time, which was as follows:
1) IP address on the computer set to 10.team.num.6
2) ALL encryption disabled on the router.
3) Computer connected to router via ethernet hard line.
4) Bridge connected to router via ethernet hard line.
5) Press the Wi-Fi Protected Setup button on the bridge (on the front, picture of a lock).
6) Click the Wi-Fi Protected Setup button on the router (through your web browser, logged into 10.team.num.4, on Wireless>Basic Setup).
7) Wait for the operation to complete.
8) Repeat if it doesn't work.
9) Drive robot in front of baffled congressmen.
Having done very little networking before, that was fun to do from scratch. Thank goodness they got roaming wireless mode to work on Ubuntu 9.04.
Unread 06-05-2009, 09:57
charrisTTI charrisTTI is offline
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
charrisTTI has a spectacular aura aboutcharrisTTI has a spectacular aura about
Send a message via AIM to charrisTTI
Three choices:
Connect router to PC with ethernet cable and access web page of router (http://10.xx.yy.5) to enter the encryption key into the router (We were given a printout at our regional with the key).
or
Connect router to bridge and router to PC with ethernet cables and access web page of the bridge (http://10.xx.yy.1) and turn off encryption.
or
Reset router and bridge to factory defaults using the reset buttons and follow directions in chapter 5 to reconfigure them
FRC 623 2003,2004,2005,2006,2007,2008, 2009, 2010, 2011
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 226 and 369 2008, 2009, 2010, 2011
FTC 3806 2010
Unread 06-05-2009, 12:35
chinckley chinckley is offline
Winner 2009 West Michigan District
FRC #1254 (Entropy)
chinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to allchinckley is a name known to all
Originally Posted by charrisTTI View Post
Three choices:
What will turning the encryption off do?
We are having the same problem. Our robot works tethered but not wirelessly.
Our problem is that the person who normally helps with the router issues is not able to help us today before the board meeting at 3 pm EST.
If it will take a while to do, we will just go with tether and try to redo it tomorrow, when we are not in such a rush.
Can anyone walk me through it?
Thanks...
2009 West Michigan District Winner
Thanks to Team 216 and Team 1918
2009 Traverse City Semifinalist
Thanks to Team 1596 and Team 47
2009 Traverse City UL Safety Award Winners
Attending 2009: West Michigan, Traverse City, & State
Unread 06-05-2009, 13:31
Ramblin' Wreck
AKA: Charles Harris
FRC #0623
Thanks...
Encryption either needs to be on at both ends (with the same encryption key) or off for there to be communications.
FRC 1900 2007
FVC 60 and 193 2006
FVC 3271 2007
FTC 3806 2010
MOEmentum: Post Ship and Pre-Competition Mr MOE General Forum 0 24-02-2007 07:34
Post-competition excitement Gui Cavalcanti General Forum 11 13-03-2004 01:42
What is your favorite post-season competition? DougHogg Off-Season Events 29 16-04-2003 14:30
Who knows about any informal post-championship competition aka Scott White Off-Season Events 4 18-05-2002 22:32
Post Competition and Pre-competition needs for 271 Chubtoad Technical Discussion 4 21-03-2002 12:17
