Go to Post How easy will it be for a driver to control 5-6 different motions at once? Most drivers only have two hands. - Kevin Sevcik [more]
Unread 05-05-2009, 15:57
Team_136 Team_136 is offline
FRC #0136
Team_136 is an unknown quantity at this point
communication to bridge problem solve!
There are many people in this forum wondering why there was no comm between the router and bridge after the competition "LUNACY".
We had the same problem and when we tried to connect to bridge via ethernets it wouldnt let you in the bridge page.
To solve this problem just get a new router and connect it to the bridge using ethernet cables. After that you should be able to go in the page and just do everything over(for the router and the bridge).
*Dont forget to have the same SSID for the router and the bridge!!!!!!*
Thats basically all we did, everything worked like it use to.
Unread 05-05-2009, 16:16
Re: communication to bridge problem solve!
You shouldn't have to get a new router. Just connect an ethernet patch cable directly from the computer to the wireless bridge. (Make sure the computer's IP address is set properly, of course.)
Unread 05-05-2009, 19:51
Don't forget that security is still set from the competition. Return to the default as in your original setup.
Drive Station Communication Problem CHSboy Control System 0 18-02-2009 18:22
Wireless problem - losing communication jalburty FRC Control System 9 09-01-2009 07:35
who can solve a rubiks cube?????? 647techangel Chit-Chat 3 14-02-2008 19:27
Visual Basic. Using a loop to solve the cosine function. sanddrag Programming 2 10-03-2006 11:45
Mars face mystery - Can/will the rovers solve this one? Elgin Clock NASA Discussion 5 30-08-2005 09:42
