Go to Post You can't observe things that aren't seen or reported. - Andrew Schreiber [more]
View Poll Results: Which game would you want to play in vex?
2005 FRC - Triple Play 13 36.11%
2006 FRC - Aim High 7 19.44%
2008 FRC - FIRST Overdrive 10 27.78%
Custom Vex Game 6 16.67%
Voters: 36. You may not vote on this poll
Unread 05-05-2009, 17:27
Re: FRC Off-Season Vex Competition Ideas
Originally Posted by Chris is me View Post
Vex motors really can't shoot anything more than a foot or so.
I recomend you check out MARS's (1523) bot from 2006. You don't need a spinning wheel to quickly shoot balls far.
Unread 05-05-2009, 17:42
NickE's Avatar
NickE NickE is offline
_
I would suggest creating vertical posts and scoring rings (such as in the 2008 FTC Game) on them. Either put 9 posts and score the game like triple play or put more and score the game like Rack and Roll. Kinda like a combination of the 05 and 07 FRC Games
Unread 05-05-2009, 20:29
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Well Twinkle Toes,
If you do choose to do a replay of a game this year, you know I will not be building your robot for you the night before this year.
Oh yeah, and trust me, I will make it rain again this year... Just like in '07
Unread 05-05-2009, 20:55
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Vex motors really can't shoot anything more than a foot or so. Basically the ony things it could shoot that far wouldn't have the mass to travel far. I guess floor shooters would be fine.
I wish I still had video to prove this but, my Sophomore Year (?) I made a 1/3 scale Aim High Robot from Vex parts that shot racquet balls (the were used in the 2006 FVC game). It used two 1:7 reductions for the shooter and used 3 motors. The motors would over heat after a while and it only shot about 1 ball per second but it shot a lot more than 1 foot. I'd imagine if you were to use some kind of small lightweight foam ball or ping pong ball you could easily shoot over 5 feet. So I'd say that 2006 could be played with vex.
I think that 2008 would be the least feasible. I'd assume it'd use something about the size of a kickball. That'd be difficult to manipulate with vex motors...
Unless of course you use on of these babies: http://www.vexforum.com/gallery/file...icture_082.jpg
-Dustin Benedict
Unread 05-05-2009, 21:17
Overdrive is mad easy to create a VEX game for. PVC for the win. I would change up the game pieces and have different ball sizes to hurdle.
Unread 05-05-2009, 21:58
I happen to know that it is quite possible (and practical) to recreate Triple Play with a VEX Starter Kit, some fishing line, and a bunch of drinking straws. You'll probably also want some wooden dowels and some cardboard for the goals.
The straws are for tetras. Cut pieces to the appropriate length, thread the fishing line through the pieces (I don't remember the pattern offhand), and tie it off the right way, and you have a perfectly good tetra. Remnants of straws can be used as alliance flags.
For the robot portion, it's really easy to do a single-joint arm...
330 did it for a fundraiser a few years back. The second day, we turned it into soccer because it was hard for people to handle the tetras with the stock robots we provided. As this is for more veteran types, that won't be as much of an issue.
Unread 06-05-2009, 08:01
dk5sm5luigi's Avatar
dk5sm5luigi dk5sm5luigi is offline
AKA: Nick Galotti
FRC #1735 (Green Reapers)
dk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud ofdk5sm5luigi has much to be proud of
Send a message via AIM to dk5sm5luigi
Another option is to used an old Savage Soccer game. (http://users.wpi.edu/~savage/) The fields are cheap to build, the games are a lot of fun, directions on how to build the fields are available, and the rules are already written.
If you would like a suggestion on a specific game I would recommend 2004, 2005, 2007, or this years.
Team 1735 Green Reapers: 2005-Present
Team 190 Gompei: 2001-2005
Team 155 Technonuts: 1997-2001
http://www.first-a-holics.com/
http://www.findrobotparts.com/
Unread 06-05-2009, 09:01
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Something I have always wanted to try, a bit like lunacy...
What if you had one goal that was a box on wheels autonomusly programmed to drive and try to avoid walls? And then the other robots tried to catch it and score some form of medium sized balls in it? I think this would be pretty cool to watch and play, and strategy would be very important.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 06-05-2009, 09:54
NickE's Avatar
_
A goal on a roomba?
Unread 06-05-2009, 10:37
Originally Posted by NickE View Post
A goal on a roomba?
Now this -- THIS is a good idea.
Unread 06-05-2009, 10:41
Joining the 900 Meme Team
FRC #0079
A goal on a roomba?
If you don't use it expect for this to pop up somewhere else. Im gonna go try to convince Kettering to let me do this at the Kickoff event. (We provide the robots and let little kids try it)
Unread 06-05-2009, 13:30
Chris is me's Avatar
AKA: Pinecone
We didn't put a goal on a Roomba, but in MVL the main goal was a Vex robot with an inverted cone on it that was designed to avoid robots. Basically you had to pin it against a wall to score... what foreshadowing!
Unread 12-05-2009, 23:01
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
There was a huge meeting of brilliant minds over the past week to come up with one sweet custom vex game.
The result was:
Vertigo
A game of strategy.
Stay Tuned, will be announced tomorrow.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Chicago Off-Season Competition Lydia_1739 Off-Season Events 3 28-04-2009 22:31
Off-season project ideas? danshaffer General Forum 27 09-04-2007 21:54
Off Season FRC Events. Pavan Dave Off-Season Events 1 22-02-2007 10:58
2005 Rochester off season comp ideas and so thread Alex Cormier Off-Season Events 15 29-04-2005 11:13
