Go to Post FIRST is supposed to be a learning experience. Learn first, win awards later. - evulish [more]
Go Back   Chief Delphi > Technical > CAD
Unread 05-05-2009, 19:22
McGurky's Avatar
McGurky McGurky is offline
Geek
AKA: Kyle McGurk
FRC #1716 (Redbird Robotics)
McGurky is just really niceMcGurky is just really niceMcGurky is just really niceMcGurky is just really nice
AutoCad Inventor 2010
I just got an E-mail notifying me that the new Autodesk 2010 software is out! Is there anything that you guys where hoping to get changed with the new version?
RTFM -Read The First Manual
You already are who you are, I may be able to show you a fancy trick or two, but the term "Better" is relative to the potential you already have.
Take a look at my website/Blog!
Unread 05-05-2009, 19:33
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: AutoCad Inventor 2010
I have a copy and I can say it is a very different layout. If you have used office 2007 it has that sorta style. Persoanlly if there was one thing that I hoped was changed would be the cube that is in the upper right hand corner in 2009 would be changed back to the old rotating method like in Inventor 2008 (did not happen). Last, if you have a school email or your teacher has a school email you can get a copy of inventor 2010 at students.autodesk.com
Unread 05-05-2009, 19:50
McGurky's Avatar
Geek
AKA: Kyle McGurk
I am in the process of downloading/installing it right now. Hmm, 2007 word, I love the layout compared to 2003, Hopefully i will like this new layout also!!!!!
Unread 06-05-2009, 12:16
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
I believe in '09 you can change your preferences to modify the appearance or turn that cube off completely - and the view manipulation controls will still work the same as in previous versions. Don't know about v2010.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 06-05-2009, 15:44
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
O downloaded a copy of 2010 and i LOVE the new layout compared to 2008. The GUI is a lot nicer, although the controls are a bit more confusing for new students if you haven't used Inventor before.
Unread 06-05-2009, 17:14
McGurky's Avatar
Geek
AKA: Kyle McGurk
I actualy think that they are easier to use and learn than before. They let you find the "hidden" features of inventor easier than ever before. and it is faster than having to go through 1,000 tabs just to do one function...
Unread 06-05-2009, 17:18
Rating user friendliness on a scale of 1-10?
Compared to ease-of-use of Solidworks 2007-2008?
Either of these would be appreciated, of course, with details.
Gracias.
Unread 06-05-2009, 19:10
McGurky's Avatar
Geek
AKA: Kyle McGurk
I have never used solidworks, and I have just been using inventor for about a year. With that said, I hope that I can still help you.
When you open Inventor, It opens to the same as it did in the 2009 version. you can open a part or start a new one the same as before, but the change comes when you start to model parts. In inventor 2009, there was just the standard menu system and at times, you spend alot of time trying to find the right function you are looking to do.
Autodesk solved this problem by switching over to a "ribbon" menu system consisting of "Assemble, Design, Model, Inspect, Tools, Manage, View, Environments, Vault and Get started" in the Assembly mode.
Assemble View: Consists of actions Such as "Place Component, Create Pattern Component(circular and rectangle), Mirror, Copy, Constrain Move, Rotate, Cable and Harness, Tube, Bill of Materials and more. Everything in this Tab is just about what there was in the top of the list in Inventor 2009.
Design View: Consists of what I call the "hidden pluses" to inventor that many people have never used before because of the way that the GUI was organized in past versions of inventor, and if used properly can save A LOT of time!! This new Organization brings out these "hidden tools". Tab consists of: Bolted connection, Clevis Pin, Insert Frame, Shaft, Spur Gear, Bearings, Belt and chain Tools, Key tools, O-rings, and Compression.
Model View: Consists of the "sketch/model tools" including "Create 2D Sketch, Extrude, Revolve, Hole, Fillet, Chamfer, Sweep, Work planes/axis/point, and patters(rectangle and circular).
Inspect view: consists of "Measure tools such as, Distance, angle, loop and area, and Interference analyzer tools.
Tools View: includes mainly other tools from other tabs combined into one tab.
View View: Includes everything needed to modify your viewing experience such as UI changes and Views.
Environments: includes switching from inventor to stress analysis, Dynammic Simulation, Inventor Studio, AEC Exchange, Weldment, and to Manage Add-Inns.
Vault: includes Vault tools
Get started: includes all the basic tabs to get you where you want to be. Such as New, Open, Projects...
In the Part File, the tabs include... Model, Inspect, tools, Manage, View, Environments, Vault, Get Started, and sketch.
Sketch Tab: includes All of the normal sketch features including line, Circle, Rectangle...in addition to Dimensioning tools like Tangent, Parallel, Dimension, Equal Etc. Also it has pattern, Modify, layout, insert and formats(construction line...) Along with A Giant FINISH SKETCH button.
Model Tab: Includes the modeling tools like Extrude, revolve and loft including tools such as chamfer, shell and thread, along with work planes/axis.
Inspect tab: includes Measure tools
Tools Tab: includes Different tools from different Tabs.
View tab: Is same as Assembly View tab.
Environment tab: same as Assemby tab.
Vault tab: Same as Assembly Vault Tab.
Get started: Same as Assembly Get started Tab
In all, I would rate it a good 9, I think the enhancements are great, and they will help a great bit!!
I just went over the changes to the GUI but there are also many other deeper changes that I have not yet seen but have been changed.
In response to other post... To get rid of the "ViewCube" just go to the "View" tab, Click "User interface" and then Un-check the "viewcube", this will make the View cube go away.
I found this link quite helpful... http://www.rand.com/imaginit/1/techn...k_inventor.htm
-Kyle
Unread 06-05-2009, 20:50
AKA: Josh
I learned how to CAD on Inventor my freshman year and did not find it that difficult to learn. FIRST provides tutorials that walk you through using Inventor, which I found very helpful. Three years ago, in my Junior year, I tried out Solidworks and have never switched back since. I personally think that you should start with Inventor and progress to Solidworks. Solidworks is an extremely powerful program and can be a little daunting for someone who has not been exposed to CAD.
Unread 06-05-2009, 21:01
McGurky's Avatar
Geek
AKA: Kyle McGurk
what is so much better about solidworks than inventor? Can you explain why it is so much better?
Unread 06-05-2009, 21:38
I don't really know how to say why its easier for me. But what I can say is that the tutorials were so straight forward and the modeling process was taught quickly in less steps than when I began learning Inventor. I guess it also depends on which tutorials you use. What I do love about SW is the insane quality of the renders. For examples, see a few of roboticwanderer's renders in CD Media. I can't really say much more than that as I didn't follow through with the long Inventor tutorials and just went to SolidWorks For me overall it was just about getting results faster. BTW, I'm not saying Inventor doesn't produce quality renders. SW is also used more in industry.
Mine:http://www.chiefdelphi.com/media/photos/32115
roboticwanderer's awesome stuff:http://www.chiefdelphi.com/media/search/results/331425
Unread 06-05-2009, 23:04
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Anybody looked at the the integration of the new FEA package?
Mark
Brick walls are for other people. - Randy Pausch
Unread 07-05-2009, 00:08
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
It's not just Solidworks. ProE and AutoCAD are both better then Inventor for one simple reason.(ignoring the many others) They are used in industry. I know of a company that uses Solidworks, one that uses AutoCAD, and one that uses ProE. However, I don't know any that use Inventor. That alone makes any one of the the three other 'main' CAD softwares better.
Inventor is primarily used to acquaint you with the mindset of a draftsmen. Think about it. Since you've learned Inventor, do you look at parts the same? I personally look at parts as extrusions, revolves, and other basic commands. I see the details of the part. That is what you need from Inventor.
Now, onto the many other reasons Inventor is a bit sub par. Each tool specializes in it's own way. The ProE is the natural powerhouse of drafting. If you want some advanced mechanics, that is where you want to go. The AutoCAD has vastly superior 2D drafting capabilities and uses way less memory. Solidworks is more of the same, but just way more in depth.
Overall, though I love Inventor, I got to say that any of the other three will suit you better in the long run. I hope my explanation covers all the bases without stepping on anyone's toes.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 07-05-2009, 07:31
McGurky's Avatar
Geek
AKA: Kyle McGurk
I cant argue for why inventor is better in any way because I have never used any other cad software besides Autodesk. The main reason that I use inventor currently is because that is what our school teaches on. This summer when I have more time, I plan on learning at least solidworks and possibly PRO-E if I have the time.
Is there anywhere to get either Solidworks or Pro-E free?
P.S. That is an awesome Render BTW!!!
Unread 07-05-2009, 07:47
kramarczyk's Avatar
Pro-E is available to all FIRST teams...
http://www.usfirst.org/community/frc....aspx?id=10990
Don't forget to grab MathCAD while you are at it.
Mark
AutoCAD vs. Inventor NextPerception Inventor 21 12-02-2007 10:29
AutoCad Inventor in KOP? Chris_Elston General Forum 7 08-01-2005 20:13
Inventor to AutoCAD rmmlg Inventor 10 14-12-2004 21:26
AutoCAD/Inventor parts library archiver 2000 3 23-06-2002 22:32
AutoCAD, Inventor, or Other D.J. Fluck General Forum 23 31-12-2001 08:59
