Go to Post "Dear Santa, all I want for Christmas is a game hint." - Gregor [more]
Unread 06-05-2009, 02:20
henrylu33 henrylu33 is offline
henrylu33 is an unknown quantity at this point
FRC Software Help
Hi I have never competed in the First Robotics competition but as a project in my Technical Writing class in college I involved in creating a manual for a local high school robotics team. I am responsible for the software portion and on the checklist there is a section that lists three parts I do not understand. Any help would be appreciated. Here are the three things:
- Describe the operation of the default program code
- Load the default program onto the robot controller
- Load the default code onto a previous year’s robot and modify it to drive in a predetermined route
Please advise on how I would best put this information in a manual to help students better understand the task at hand. Thank you.
Unread 06-05-2009, 06:52
LVMastery LVMastery is offline
LabVIEW Educator and Mentor
AKA: Ben Zimmer
FRC #0843 (Wildcats)
LVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud of
Re: FRC Software Help
Henry,
This is a wonderfully challenging task you have been given.
The first decision you will have to make is which programming language you will be using: C++ or LabVIEW.
If you use LabVIEW, I've created a video blog which will take you through many of the required steps. Check out our blog at www.LVMastery.com/FRCTipJar
All the best,
Ben Zimmer
Ben Zimmer
Enable Education
www.EnableEducation.com
www.FRCMastery.com
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Unread 06-05-2009, 21:16
pyr0b0y pyr0b0y is offline
Programmer/Electrical
AKA: Josh
FRC #0253 (Mills Robotics Team)
pyr0b0y is an unknown quantity at this point
Send a message via AIM to pyr0b0y
If you are going to be using Windriver, the default program code, SimpleRobot, uses arcade drive and a very basic autonomous mode, the teleop mode just allows tank drive with leftStick/rightStick.
Loading the code onto the robot is done by setting the cRio as the remote system then downloading onto the robot.
To accomplish the last part, you will use autonomous mode. a simple example of setting a predetermined is
void Autonomous(void)
		GetWatchdog().SetEnabled(false);
		myRobot.Drive(0.5, 0.5); 						// drive forwards half speed
		Wait(1.0); 											// for 1 second
		myRobot.Drive(0.75, 0.75); 						// drive forwards three-quarter speed
		Wait(4.0);											// for 4 seconds
		myRobot.Drive(-0.5, 0.75);						// turn left
		Wait(2.0);											// for 2 seconds
		myRobot.Drive(0.75, -0.5);						// turn right
		myRobot.Drive(0.5, 0.5);						// drive straight at half speed
		myRobot.Drive(0.75, 0.75);						// drive forwards at 3/4 speed
		Wait(5.0);											// for 5 seconds
Hope that helps!
Software for progaming in FRC frcchile Programming 14 29-12-2008 20:18
FRC Workshop (Atlanta) - Using Collaboration Software to Jumpstart Your FRC Team PTC_FRC CAD 0 16-04-2008 10:37
Event Match Software Help Kims Robot Technical Discussion 1 27-10-2006 02:04
Spoiler: Could this be the new software for the FRC 2006? Chris_Elston Rumor Mill 20 21-11-2005 14:14
Software Help AzNDynasty FIRST Lego League 1 25-10-2005 17:19
