Go to Post To have respect for the process you are in right now, respect the knowledge around you by using it to your full advantage. - Scott Ritchie [more]
Unread 07-05-2009, 09:02
Studentish Studentish is offline
FRC #2252
Studentish is an unknown quantity at this point
Laptop is not finding the cRIO properly?
Our team has made the purchase of a new cRIO device, and we have been trying to get it up and running. Our power supply meets all the requirements in voltage and amperage, and everything lights up properly. The computer will recognize the cRIO is hooked up, but will not be able to connect and run the imaging tool. The IP address on the cRIO is set to 10.22.52.2, so we attempted to change network connection’s IP to 10.22.52.2, but the address will not set to that. Instead of being able to set the first number set as “10,” we can only set the first number as one digit. The internet and other forums don’t seem to be going in the right directions, but if anyone can offer any help it would be greatly appreciated. Thank you!
Unread 07-05-2009, 09:12
rdlevy1215's Avatar
rdlevy1215 rdlevy1215 is offline
FRC #1676 (Pascack Pi-oneers)
rdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud ofrdlevy1215 has much to be proud of
Re: Laptop is not finding the cRIO properly?
The new cRio's address should actually be 10.0.0.2 and when you run the imaging tool it will reset the IP of it. Set your computer's static IP to 10.0.0.6 and you should be able to connect and then re image. Once it has COMPLETED reimaging then you must reset your computers IP to 10.xx.yy.6 to talk to it further through Labview or WindRiver. Also be sure to have the subnet mask on your computer 255.0.0.0 with the default gateway and DNS servers of 10.xx.yy.4
Robert D. Levy
Team 1676, "Pascack Pi-oneers"
http://www.team1676.com/
admin@team1676.com
Unread 07-05-2009, 09:22
FRC #2252
Still when setting the IP address on the computer I cannot set "10.0.0.2" I can only set "1.0.0.2".
Unread 07-05-2009, 09:48
FRC #2252
Thank you for your time rdlevy1215, I appreciate it.
The issue was in the keyboard, it's not accepting half of the key inputs, so I'm using the character map to find the characters I need.
Again, thank you.
Unread 07-05-2009, 12:03
rdlevy1215's Avatar
Again, thank you.
You could use the on screen keyboard in windows as well too -- Start-->Programs-->Accessories-->Ease of Access/Accessibility (Depending on Vista/Win7 or XP, respectively)
Robert D. Levy
admin@team1676.com
Laptop not finding router popo308 FRC Control System 7 16-01-2009 14:09
Tricks getting the CRIO to talk to laptop mac7attack FRC Control System 10 08-12-2008 09:20
1 joystick controls not turning properly andrew_4_life Programming 4 28-03-2008 01:22
CMU Cam not Tracking Properly on Robot coastertux Programming 6 29-01-2006 00:02
