Go to Post I don't have enough vacation time for them to start allowing video replay. - TJP123 [more]
Unread 07-05-2009, 14:36
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Radio Problems?
Our team hasn't been able to connect to our robot via wireless control since it returned from nationals. We are able to tether and so we are wondering if any other teams have experienced this problem? Or if anyone knows why? Our student programmer has found that the driver station is reading linksys and not 744 and thinks that is the problem. So if anyone knows how to update that, it would be helpful.
www.sharkattack744.com
Unread 07-05-2009, 14:45
Re: Radio Problems?
Try clearing the encryption. Seems that it won't work right with the encryption on. There's a few threads out there about how to do that.
Unread 07-05-2009, 16:10
Re: Radio Problems?
At competition, your WGA bridge was configured to use WPA encryption to connect to the "744" access point. Go into its administration page at http://10.7.44.1/ and set the security from WPA to None. Or, if you know what the encryption key is (a long string of random-looking characters), you could set the WRT router to have the same one.
The other option is to do a factory reset and follow the original directions to configure it from the beginning.
I don't know how your programmer is determining what the driver station is doing. It goes by IP address only, and has no concept of an SSID (which is what "linksys" and "744" are examples of).
Unread 07-05-2009, 20:30
Re: Radio Problems?
Thank You I'll relay this to our programmer.
Unread 08-05-2009, 07:38
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: Radio Problems?
This thread has instructions on how to reconfigure your wireless setup in order to work.
Some Radio Problems Browzilla Control System 4 30-04-2008 12:06
Radio Problems BenB Programming 4 13-02-2008 16:06
Radio Problems JimWright949 Control System 7 04-02-2008 20:46
Radio problems Charley Control System 11 15-02-2005 09:44
Radio Problems KWalsh Programming 3 24-02-2004 17:25
