Go to Post Education doesn't have anything to do with how much money a person can make. Experience, Perseverence, and Character do. - Jnadke [more]
Unread 07-05-2009, 16:29
JoeyTNT280's Avatar
JoeyTNT280 JoeyTNT280 is offline
Scouting
AKA: Joey
FRC #0280 (TnT)
JoeyTNT280 is an unknown quantity at this point
Send a message via AIM to JoeyTNT280
No Comms Issue....
We have had a no communications issue since atlanta, this problem isn't new to us but we seem to have forgotten how to resolve the issue here are the steps we took in order sort of.
1# - Hard reset both the Router and the Wireless Bridge
2# - Set the IP on the Router again (Wireless Bridge didn't allow us on)
3# - Various resetting and trying to connect the Wireless Bridge
4# - Finally able to reset the IP on the Wireless Bridge due to instructions on here.
5# - Checked everything to see if it had the same IP address it was supposed to which every IP was or appeared to be right.
6# - Hit head off of our table when it didn't work
Could anyone explain what we missed or if anything needs to be done we need it fixed as soon as possible. Thanks
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 07-05-2009, 17:00
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: No Comms Issue....
If you reset the router and Wireless Bridge you will have to set all the settings up according to the Control system manual (IP, SSID, etc.)
Also make sure that the security on both devices is set to "Off".
Unread 07-05-2009, 17:05
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
We did thats the thing. We did everything the Control System Manual told us to do and it doesn't seem to like that very much
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 07-05-2009, 17:06
Digital-Goliath Digital-Goliath is offline
AKA: Taylor Amarel
FRC #1124 (Uberbots)
Digital-Goliath is an unknown quantity at this point
Send a message via AIM to Digital-Goliath Send a message via MSN to Digital-Goliath
Based on what you said, I would first check to make sure all Ethernet cables are correctly plugged in. Second Check if the LED next to the driver station ethernet port that your using is lit to ensure communication. Third make sure you are not using a cross over cable to connect the driver station to the router or the gaming adapter to the Crio. The only place the crossover cable should be used in between the Crio and the Camera, otherwise just use standard patch ethernet cable.
Unread 07-05-2009, 17:11
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
Should the driver station light be solid or flashing? It might also be our cRio because of our tethering issues. I'll have to look into that thanks
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 07-05-2009, 17:22
AKA: Taylor Amarel
The driver station light should be solid. If it is flashing that indicates interrupted communication. That could be a result of a faulty cable, faulty connection, or in worst case scenario a fried ethernet port on the driver station. Which seems to be happening a lot due to the static discharge. Speaking of that, is your driver station grounded?
Unread 07-05-2009, 18:13
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
Yes our DS is grounded as per the update. I think we may have ruined a port on our DS and cRio
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 11-06-2009, 19:11
ExarKun666's Avatar
ExarKun666 ExarKun666 is offline
Ben Error/MC Ben/NC Ben
AKA: Ben Kellogg
FRC #2429 (LCEC)
ExarKun666 is an unknown quantity at this point
Send a message via AIM to ExarKun666 Send a message via MSN to ExarKun666 Send a message via Yahoo to ExarKun666
Our team just really uncrated the robot, and tested it today, and we go the no comms sign too, when wireless
What we have done:
1) Checked to see if it works tethered [it does]
2) Looked at control guide, and plug the laptop into each ethernet port, and pinged the IP Address that the control guide said on it, including computer
3) Re-downloaded code [while tethered] power cycled [turn off -> on] robot, and try to run wirelessly again [didn't work though]
4) Think to ourselves why we may be having this problem
I thought it was because of that code they gave us at the competition for the black wireless box you put on the robot, I forgot exactly what you called it but I remember having to but some like password code thing in at regionals and I THINK that's the reason it's not working, but I am not sure.
Any suggestions?
Ben Kellogg
Team Sites: [LCEC Site] [FRC/FLL Site] [LCEC Blog]
Unread 11-06-2009, 20:24
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
Be sure to check which port you are plugged in to on the router. Both times our team has had this problem, it was after an extended break from the robot and I accidentally plugged the cord from the DS into the Internet port on the router or the bridge into port 2 on the cRio instead of port 1. Verify that ALL connections are plugged into the correct spot.
Hook the laptop up to the DS and ping all of the different devices to see where you lose your connection.
Unread 11-06-2009, 20:32
It's because of "...some like password code thing in at regionals..."
Your robot only listens for a wireless signal with the right password.
Just connect your laptop via ethernet cable to the robot's radio and turn off the WPA.
Basic -> Wireless
Security Mode: None
"No Comms" sabruce01 General Forum 56 09-03-2009 13:50
FTP Issue Eugenia Gabrielov General Forum 7 27-02-2005 05:07
Autonomous issue NJ M. Hicken Programming 2 16-02-2005 21:59
Software Issue patTeam241 Programming 0 28-01-2005 17:12
