Go to Post A FIRST adage: You can make an Offensive robot play defense more effectively, than you can make a Defensive robot play offense. - Enigma's puzzle [more]
Go Back   Chief Delphi > Technical > CAD
Unread 07-05-2009, 08:29
lyezzie's Avatar
lyezzie lyezzie is offline
Luke
FRC #0540 (Talon 540)
Team Role: CAD
lyezzie is an unknown quantity at this point
Question Pneumatics on Inventor
All right...I have been trying to put pneumatic tubing on our CAD for a robot that VirginiaFIRST asked us to create outsude of FRC. In the main assembly, I was able to create a "route" under the "Create Pipe Run" icon. The only thing that appeared is the like path without the tubing. I've tried to use a sweep on 2 circles and tried to use the route as the 2nd sketch. The computer can't find any materials either. Is there anything I am doing wrong or do you know how to fix this?
Unread 07-05-2009, 08:34
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: Pneumatics on Inventor
I have found it is best to do a harness inserted of a pipe run. You would instead of choosing wire size you choose the default and then go on each wire and change it to render in model and the size to the same size pneumatic tubing.
I did the hose like the one below in the way i described.
Unread 07-05-2009, 19:23
lyezzie's Avatar
Luke
Team Role: CAD
Question Re: Pneumatics on Inventor
That's Great! Only one issue... I will be the first person on my team to try and put tubing, or like you said, harnesses, on the robot's CAD. So...what do I do to make that harness
Unread 07-05-2009, 20:26
Jeff 801's Avatar
Drakan290 made an excellent how-to guide for making wires. Its the same idea but insted of using a special wire size you choose the default size then when you get to this step
"Exactly what we want; except the segment we created is still blue... To fix that, we right click on the segment, and go to Harness Properties.
Go to the tab that says Display. Uncheck the "From Loom" option. There should be a drop down menu, and you should select Red from here."
On the occurrence tab of the menu instead of choosing size based on wire you un check that box and then put in the size of the pneumatic tubing and then on the next tab "display" you choose what ever color you want the tubing to be.
http://www.chiefdelphi.com/forums/sh...ad.php?t=64206
Unread 07-05-2009, 20:32
lyezzie's Avatar
Luke
Team Role: CAD
Thumbs up Re: Pneumatics on Inventor
Thank you so much. I got it now and the CAD is almost complete. Thanks again!
Inventor 2008 file open in Inventor 7? VEN CAD 1 09-02-2008 17:57
Inventor 2008 files in Inventor 11 pufame CAD 1 18-09-2007 19:19
Inventor 2008 // last thread EVER about chains in Inventor? Dan Zollman Inventor 10 10-07-2007 20:01
help with the inventor[robot part missing] (ajuda no inventor[parte do robo faltando] team 2244 Inventor 6 12-02-2007 06:16
Inventor 7 different from Inventor 8? RudimentaryPeni Inventor 9 11-11-2004 16:48
