Go to Post Yes, a good driver can effectively be the element that closes the loop, but only when there is a driver at the controls. - Alan Anderson [more]
Unread 24-06-2002, 04:03
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Number of teeth is not the only issue
Posted by Raul at 05/06/2001 7:01 PM EST
Engineer on team #111, Wildstang, from Rolling Meadows & Wheeling HS and Motorola.
In Reply to: 66 is the smallest I would go.
Posted by Joe Johnson on 05/04/2001 5:33 PM EST:
I would ask for 72,84 and 96 teeth.
However, it is also important that they use the right materials and gear thickness. Plastic gears will NOT do; we need steel or maybe brass. The thickness of the gear should be 6mm minimum to carry the dynamic loads.
Also, we need a useful hub design that can be mated to idler shafts. A max hole diameter of 6mm for the shaft will allow us the flexibility to drill/ream the hole to the shaft size we need. If the gear is solid, then fine; if it has spokes then the outside hub diameter needs to be at least 25mm.
Raul
[IMG] code is Off
Helical gears that come with new drill motor Joe P Technical Discussion 4 12-01-2003 11:09
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
spur gears & fishers ...newbie question... archiver 2001 3 23-06-2002 23:17
Need help! What kind of gears are we allowed to use?? Randy_Ai Technical Discussion 3 23-01-2002 22:56
How do i make gears in inventor? mnkysp6353 Inventor 1 16-01-2002 02:31
