Go to Post Just remember: the tubes aren't a life saving device, the are a life CHANGING device! - Koko Ed [more]
Unread 08-05-2009, 17:42
JoeyTNT280's Avatar
JoeyTNT280 JoeyTNT280 is offline
Scouting
AKA: Joey
FRC #0280 (TnT)
JoeyTNT280 is an unknown quantity at this point
Send a message via AIM to JoeyTNT280
Labview Desktop Application
Because I haven't actually tried to look for this and I am away from my programming computer is there anyway to create a program in LabVIEW that can be run without any LabVIEW software on the computer? (I.E. - Scouting programs and such) Thanks for your time
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 08-05-2009, 21:52
Re: Labview Desktop Application
Yes, you can make a regular Windows executable.
P.S.
You can test just such an executable only program that's posted in CD whitepapers http://www.chiefdelphi.com/media/papers/2177
Unread 08-05-2009, 22:32
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
Wow, thank you. You have solved two of our issues in one post thanks a lot.
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 09-05-2009, 09:24
In LabVIEW the option to create a stand-alone executable is in your code's Project Explorer window under "My Computer" under "Build Specifications"
Right click on Build Specifications -> New and you'll see the option "Application (EXE)"
You won't see that same option under Build Specs for "RT CompactRIO...". You only get it when the target is a Windows machine, i.e., My Computer.
Unread 09-05-2009, 14:48
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
Every time ive built a windows executable, ive needed to have a labview framework installed on the client computer. Its a 50 megabyte download from national instrument's site, and i havent found a way around making the end user download this (short of bundling it with the application)
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 10-05-2009, 21:16
dqmot17's Avatar
dqmot17 dqmot17 is offline
Orange Hat
FRC #0247 (Da Bears)
Team Role: Webmaster
dqmot17 can only hope to improve
Send a message via AIM to dqmot17
i think there is a way to make an app in say c++ that opens the labview app in a kind of virtualization with the framework inside of it...but i doubt anyone understands what i just said and it make life a lot harder....
just download the framework....
2009 Championship Finalists & 3 Blue Banners
Unread 10-05-2009, 21:21
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
Ryan what you said sadly made sense. However that is really complicated and doesn't do anything for you
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 10-05-2009, 21:25
dqmot17's Avatar
Orange Hat
it would get you a labview app on some without labviews framework installed....but besides scouting there would be really no point...
Unread 10-05-2009, 21:27
JoeyTNT280's Avatar
Scouting
AKA: Joey
FRC #0280 (TnT)
There would be no point even with scouting. you might as well have it with the program in a Zipped file like someone else suggested
Programming
Scouting
Pnuematics
TnT 280 Robotics
Unread 13-05-2009, 09:32
What you described is pretty much what that download delivers. A LV executable is a small C++ app that bootstraps the LV execution engine and enqueues the various main routines you've selected. The execution engine as well as the controls and indicators and other support code are in the runtime DLL that is downloaded.
If you want more control, you can build more in C++, and build the LV stuff into a DLL instead, but the windowing stuff gets a bit tricky.
As for what to download and install, your choices are ...
Install the development tools -- they are essentially free for any FIRST related activities, which includes homework, programming in off season, etc.
Install the runtime support -- it will let you run apps, but then you need a development system to build them.
If someone is a complete software newbie, then perhaps the runtime is right for them, but just because someone isn't the team programmer doesn't mean they fit this category. LV, after all, was designed to be a programming tool for engineers and scientists, not just computer scientists. In years to come, hopefully the mechanical, electrical, and scouting teams will get as much use out of it as the programmers.
Greg McKaskle
Opening Labview Programs : Desktop Only??? Delian NI LabVIEW 1 23-12-2008 23:13
NI LabVIEW and Data Acquisition Pilot Program 2006 Application Ready! Danny Diaz National Instruments LabVIEW and Data Acquisition 2 18-10-2006 15:55
Ball Speedometer - LabVIEW Application Vince National Instruments LabVIEW and Data Acquisition 7 13-03-2006 18:32
CMUCam2 LabVIEW Application problem itsdamoose LabView and Data Acquisition 1 09-02-2006 20:59
Google Desktop Leon Machado IV Chit-Chat 9 22-08-2005 16:46
