Go to Post Ideally, you'll make sure your drive system can handle some Irritating Failures without them becoming Paralyzing Failures. - Billfred [more]
Unread 12-05-2009, 10:07
bernieseaholm bernieseaholm is offline
FRC #2960 (automation nation)
bernieseaholm is an unknown quantity at this point
parallax stamp and roboteq ax2550 seaholm
seaohlm is working on segway like device, balancing robot. we are currently using a parallax stamp bs2 microcontroller connected to a roboteq motorcontroller(ax2550) we are having difficulty with programming stamp to output data via rs232 in readeable format to ax2550. I think we need someone who i really good with stamp programming to help.
link below is to parallax forum with info about our project.
http://forums.parallax.com/forums/de...x?f=5&m=347344
thanks
bernie
Unread 13-05-2009, 11:35
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: parallax stamp and roboteq ax2550 seaholm
thanks
bernie
Does the AX2550 accept digital rs232? The stamp only outputs a 0 - 5V rs232 swing and you may need to add a maxim chip to do a level up conversion for "true" rs232.
You may also need a pull up or pull down resistor as documented in the SEROUT help file depending how you have it configured.
You seem to be reading a pulse that ranges from about 1.7ms to 2.25 ms, then trying to normalize it with a base of 2180 so a range of 0 - 639 (2819 - 2180) multiply by 26112 taking the top 16 bits (effectively dividing by 64K) so you range from 0 to about 255 and subtract 127 which means you will have a value that ranges from 0-127. Were you trying to make a virtual joystick? Just curious.
Steve
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
STAMP Release: STAMP Match Calculator Ethulin General Forum 3 17-02-2006 10:05
Parallax Stamp DIED!!! Carl Owenby Programming 1 16-02-2003 14:44
Parallax Basic Stamp Workshop archiver 2000 1 23-06-2002 22:08
Will the parallax stamp software run win win2k? Joe Ross Programming 5 25-08-2001 13:38
