Go to Post TIME is the one commodity you cannot buy more of. - Andy Brockway [more]
Unread 13-05-2009, 14:15
Re: Review of a small motor controller schematic.
Austin,
The difference in capacitor values stems from Tantalums being very close to labeled value and electrolytics being a little less precise and varying over their life. I like to use the bigger caps if I have room. I also cannot use tants for audio so it makes less different parts to buy for my work. The other thing is tants tend to short when they go bad or lightning happens. On a power supply that can be catastrophic. If you find that regulator oscillates, you may have to add a .01-.1 cap in parallel with the output cap near the regulator.
Motor speed sensing with the Jaguar motor controller? mminutto FRC Control System 5 13-01-2009 18:13
small banebot motor with 64:1 gearbox burkey_turkey Motors 16 29-01-2007 01:48
Small and Large CIM Motor Data Danny Diaz National Instruments LabVIEW and Data Acquisition 0 23-02-2006 03:26
Small motor used as sensor JoelP Rules/Strategy 19 07-02-2006 17:25
What with the small motor? Robb Gerber General Forum 10 10-01-2002 14:10
