Re: Capacitor Value
That is correct, but he has caps with one and two digit 'codes'.
If they are physically small - say, the size of a lentil or smaller - that could be the actual value in picofarads. A capacitance meter is $35, maybe someone you know has one you can borrow? I have one, but I fear a trip to NJ would absorb some of the savings... |
Re: Capacitor Value
Also, I love that you compared them to the size of a lentil. |
Re: Capacitor Value
If you want I'll send you my grab bag from RS from the mid 80s....no charge...they seem to be marked better.
Re: Capacitor Value
I found this webstie finally
http://www.ehow.com/how_4480564_lear...apacitors.html specifically this paragraph "Learn to read 2-digit capacitors. Ceramic disc capacitors are often labeled with just two numbers. if the value is less than one, these capacitors are generally measured in microfarads. If the value is more than one, it indicates a value in picofarads. For example, a capacitor that reads ".01" will have a capacitance of 0.01 μF (microfarads), or 10,000 pF (picofarads). A capacitor labeled "15" will have a value of 15pF." odd. I ahve never heard this before. Thanks for all the help |
Re: Capacitor Value
I guess I should have explained better in my first post...oh well
Re: Capacitor Value
Although the two digit code represents picofarads below 100, don't be fooled by a marking that is obscured or rubbed off. Use a bright light and if the cap is dipped in parafin, the last digit might be under a drip. |
| GetAlliance value | nathanww | C/C++ | 2 | 15-02-2009 11:09 |
| pic: Flux Capacitor | Arefin Bari | Extra Discussion | 28 | 17-11-2008 21:45 |
| Capacitor Question | Ronald_raygun | Electrical | 17 | 22-02-2007 08:06 |
| pic: 610 Flux Capacitor (after teaser 2) | The_Goodie | Robot Showcase | 10 | 04-02-2005 22:23 |
| Value of Defense | archiver | 1999 | 4 | 23-06-2002 22:21 |
