Go to Post 2011. Tried swerve. Didn't move for 1.5 regionals. - cadandcookies [more]
Unread 15-05-2009, 13:43
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Re: **FIRST EMAIL**/Java and Orbit Balls
Originally Posted by The Lucas View Post
Pointer arithmetic. It can be useful if used properly. However, I wouldn't encourage students new to C++ to use pointer arithmetic on the robot, unless of course, you want them to experience the frustration of the dreaded "Seg Fault".
char *ptr = malloc(SIZE);
ptr + i is equivalent to &ptr[i]. Both cases boil down to just a load effective address instruction. Besides the obvious that Java hides the virtual address of all values in the symbol table, I don't see how you are missing anything by not being able to explicitly use pointer arithmetic. The point of pointer arithmetic is to compute the address of an element in an array. the "[]" operator retrieves that element and many people find this interface more intuitive. There is no performance advantage of using pointer arithmetic and there is nothing you can't do with the "[]" that you can do with pointer arithmetic (as the "[]" operator just encapsulates pointer arithmetic).
**FIRST EMAIL**/Java and Orbit Balls *****Orbit Ball Discussion**** Pjohn1959 FIRST E-Mail Blast Archive 44 18-05-2009 20:19
"Java, Sun SPOT and the FIRST Robotics Competition" pogenwurst Programming 54 02-05-2009 23:37
Amazing Circuit Build and Simulation Java Applet Chris_Elston Electrical 2 26-06-2008 19:36
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 17-01-2008 14:44
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
