Go to Post FIRST should come with a warning label. - Tim Sharp [more]
Unread 15-05-2009, 22:20
Re: **FIRST EMAIL**/Java and Orbit Balls
Originally Posted by The Lucas View Post
[SIDE RANT] I think you are missing the point (sorry for the pun). The point of pointer arithmetic is to compute the address of an element (the array data structure is optional). If you can get that address by simply adding to a pointer (stored in a register) that is more efficient than computing that address by loading a symbol and adding the result of a multiplication (indexing an array using a variable).[/SIDE RANT]
The efficiency is not what you suggest it is. Pointer arithmetic adds the result of a multiplication too: addition and subtraction are scaled by the size of the structure pointed to.
**FIRST EMAIL**/Java and Orbit Balls *****Orbit Ball Discussion**** Pjohn1959 FIRST E-Mail Blast Archive 44 18-05-2009 20:19
"Java, Sun SPOT and the FIRST Robotics Competition" pogenwurst Programming 54 02-05-2009 23:37
Amazing Circuit Build and Simulation Java Applet Chris_Elston Electrical 2 26-06-2008 19:36
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 17-01-2008 14:44
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
