Go to Post For some strange reason, people always seem to spell my last name incorrectly. I'm not really sure why. - Karthik [more]
Unread 15-05-2009, 22:56
Re: **FIRST EMAIL**/Java and Orbit Balls
Originally Posted by Alan Anderson View Post
The efficiency is not what you suggest it is. Pointer arithmetic adds the result of a multiplication too: addition and subtraction are scaled by the size of the structure pointed to.
But, at least in C, the size of the structure is a known quantity at compile time, so I would imagine that most of the time that multiplication can be eliminated by the compiler. And then on top of that, sometimes the multiplication will be by a power of 2, so the compiler will use a cheap shift operation.
Unread 15-05-2009, 23:46
This does not describe a difference between array indexing in Java and pointer arithmetic in C.
**FIRST EMAIL**/Java and Orbit Balls *****Orbit Ball Discussion**** Pjohn1959 FIRST E-Mail Blast Archive 44 18-05-2009 20:19
"Java, Sun SPOT and the FIRST Robotics Competition" pogenwurst Programming 54 02-05-2009 23:37
Amazing Circuit Build and Simulation Java Applet Chris_Elston Electrical 2 26-06-2008 19:36
Eclipse Plugin, Linux, and a Java Loader shtylman Programming 5 17-01-2008 14:44
Learn C, C++, and Java with new board game. Elgin Clock Programming 8 04-11-2005 13:28
